10-20-2006, 12:26 AM | #1 |
Saving one 72 at a time!!
Lifting questions
Is there anyway to lift a 1/2 ton - ?
Can the rear control arms be replaced with leafs w/out changing the frame. Does any one make a front end lift system (Control arms - coils- pitman-etc..) Or is the easiest way to find a 4x4 frame??
Born American - Living American - Will Die American Love it or leave it ! ! |
10-20-2006, 01:17 PM | #2 |
Chris
Re: Lifting questions
What kind of truck is it?
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
10-20-2006, 04:32 PM | #3 |
72 Cheyenne Super - 1/2 ton - and has the rear lower control arms.
10-20-2006, 05:11 PM | #4 | |
They make pre-runner kits if you want to lift the 2wd. If your looking for a 4x4, it's easier to get a rolling chassis IMO. |
10-20-2006, 05:11 PM | #5 |
The frames are different between the two(leaf and coil).
10-22-2006, 07:37 PM | #6 |
Here are some other threads about lifting a 2wd...There is also one about 67-72.. most are 73-87, the front is the same, the rear is different obviously..
http://67-72chevytrucks.com/vboard/s...d.php?t=212552 http://67-72chevytrucks.com/vboard/s...d.php?t=203445 http://67-72chevytrucks.com/vboard/s...d.php?t=204269
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
