Outlandish Trends - FL
drop spindle
Forgive my ignorance, but the PO had put disc brakes and spindles on the front of my truck b4 I got it and I'm trying to figure out if they're 73-87 spindles or if they are aftermarket drop spindles. My truck is bagged and at full dump I still have like 2 inches or so between the concrete and the front crossmember. My cups are cut down to 1/2" in height, so they are not limiting me. Anyone have any pics of drop spindles vs. stock spindles so I can identify what I have? I tried looking at McGaughys and Belltech but their sites aren't so hot for detailed pics.
-Bret 67 short-fleet sold! |
Re: drop spindle
Drop on the left, stock on the right:
![]() Notice the stock spindle is near the bottom, level with the tie rod mount. Last edited by jimmydean; 10-20-2006 at 08:46 PM. Reason: stock spindle |
![]() Join Date: Apr 2004
Re: drop spindle
I think your A arms will hit b4 your crossmember.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Happy to be here
![]() Join Date: Mar 2000
Re: drop spindle
That is correct. This is my 82 Blazer with 3" drop sindles.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 10-20-2006 at 11:30 PM. |
Re: drop spindle
thanks guys! That helps a ton.
Re: drop spindle
What are the differences between the 71-72 spindles and the 73 and up? I was wondering because my truck is 5 lug with disc and I don't know what kinda spindles they are to buy parts for it.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
Formerly LSC71
Re: drop spindle
There isn't a whole lot of difference other than they used different upper ball joints in 71-72 than on 73-up. Haven't tried to swap the balljoints in the two different arms but I do know that is one of the main differences.
#8 | |
Re: drop spindle
![]() I need new rotors and pads is why I am wondering. Thanks
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() Last edited by st1x10; 10-26-2006 at 08:18 PM. |
Formerly LSC71
Re: drop spindle
I can't say for sure if they are the same. I do know, however, that you can swap the brake calipers from the two. The only change I had to make was where the "banjo"style fitting bolts in, you have to do a little grinding for it to seat right and get a good seal.
