Old 10-21-2006, 11:27 AM   #1
snacob14
brakes diving
I just went and looked at a 68 two wheel drive that was a six cyl three speed. The brakes were pretty bad it seemed. They really would dive to the left when I would touch them, they seemed to work good but they would grab pretty hard to the left, also it didn't have power steering, how hard of a conversion is that.
snacob14 is offline   Reply With Quote
Old 10-21-2006, 04:56 PM   #2
71/454
Turbo Guy
71/454's Avatar
Re: brakes diving
sounds like it needs a set of calipers, remember to change both or else it'll pull the other way in a couple months. The power steering conversion is simple just grab the whole setup from a 73-87. Just remember to get it all of the same truck because the fittings are standard on some and metric on the newer years. The only hard part I would think would be to get the pump to mount to a six, but there must be some brackets still out there for a six
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
Old 10-21-2006, 05:24 PM   #3
kwmech
Re: brakes diving
68 would be drums, unless it has been converted already, could need new lining, adjustment or a wheel cylinder could be frozen. The power steering conversion is relatively easy if you can locate the correct brackets for the I6
Old 10-21-2006, 06:02 PM   #4
cdowns
cdowns's Avatar
Re: brakes diving
i'd think maybe a leaky cylinder
Old 10-21-2006, 06:58 PM   #5
71/454
Turbo Guy
71/454's Avatar
Re: brakes diving
I digress, I guess I didn't pay attention. My new vote is for a leaky cylinder as well
12 bolt diff
Old 10-21-2006, 07:08 PM   #6
msgross
msgross's Avatar
Re: brakes diving
Just do a disc swap and be done with it. Wish I could but 68 4x4's have to have new axles.
msgross is offline   Reply With Quote
Old 10-22-2006, 12:20 AM   #7
qksilver
Re: brakes diving
Later model discs will bolt on to the drum closed knuckle front axle. Pull every thing off from the steering knucle out and bolt on
qksilver is offline   Reply With Quote
Old 10-22-2006, 08:27 AM   #8
chipflyer
chipflyer's Avatar
Re: brakes diving
I think its the RH brake hose. It is very common to find these old hose's completely blocked. Brake fluid seems to disintegrate them internally over time and they plug.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 10-22-2006, 11:42 AM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: brakes diving
Wheel cylinders,shoes and hoses.They are 35 years old,also turn the drums and spend $20.00 or so for a rebuilt MC.You're probably looking at about $150.00 in parts for the good stuff.Brakes are not the place to cheap out.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-22-2006, 12:16 PM   #10
mrein3
mrein3's Avatar
Re: brakes diving
Jeff
It may be the RH hose. What ever the problem you have to look at the RHS. If it is diving hard left when you stop you have something hung up on the RHS. If the RHS is hung up, it heats up. Then when you hit the brake that side has faded and your left does all the stopping. I bet it pulls right when you go down the road. If it doesn't pull right look for a leaky right front wheel cylinder. It could be leaking out and causing the right to have little or no stopping ability.
Either way (stuck rhs or leaky cylinder) it is an easy fix. Just go easy if you buy it until you get it fixed right.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
