Old 10-21-2006, 01:39 PM   #1
70GMCer
70GMCer's Avatar
411 Gear?
The numbers on my 12 bolt ring gear say 11-41 GM. Can't read the pinion gear. Is this a 411 gear rear?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 10-21-2006, 01:47 PM   #2
Olden Days
Living In The Past
Olden Days's Avatar
Re: 411 Gear?
I really dont know but I will take a guess. 11 is the pinion tooth count and 41 is the ring gear count. 41 divided by 11 = 3.727. rounded off = 3.73
Count the teeth and divide and know for sure
Olden Days is offline   Reply With Quote
Old 10-21-2006, 06:10 PM   #3
centsless
sufficiently talented fool
centsless's Avatar
Re: 411 Gear?
I believe that is correct.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 10-21-2006, 06:20 PM   #4
kwmech
Re: 411 Gear?
It is correct---divide the ring by the pinion
Old 10-21-2006, 08:30 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Re: 411 Gear?
This may have been posted before.....
Ratio 2.56:1 Tooth Combination 41,16
Ratio 2.73:1 Tooth Combination 41,15
Ratio 3.07:1 Tooth Combination 43,14
Ratio 3.08:1 Tooth Combination 40,13
Ratio 3.08:1 Tooth Combination 37,12
Ratio 3.31:1 Tooth Combination 43,13
Ratio 3.36:1 Tooth Combination 37,11
Ratio 3.42:1 Tooth Combination 41,12
Ratio 3.55:1 Tooth Combination 39,11
Ratio 3.73:1 Tooth Combination 41,11
Ratio 4.10:1 Tooth Combination 41,10
Ratio 4.11:1 Tooth Combination 37,9
LockDoc
Leon
Old 10-21-2006, 11:23 PM   #6
Bob Moore
Re: 411 Gear?
This is also very good info from LOCK DOC.
First the key/lock data and now this.
You gotta love the board - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 10-21-2006, 11:34 PM   #7
LockDoc
LockDoc's Avatar
Re: 411 Gear?
That's what happens when it's cold and rainy outside. I get bored.....
LockDoc
Leon
Old 10-22-2006, 07:20 AM   #8
70GMCer
70GMCer's Avatar
Re: 411 Gear?
Thanks for the info......kinda glad it isn't a 410......A 373 with a planned 700r4 will work just fine.......
steve
1997 GMC Sierra Ext
1965 Mustang
