Old 10-21-2006, 07:21 PM   #1
1969C/10
Unskilled Labor
1969C/10's Avatar
Question Help With Removing Dash Pad
I want to take off my dash pad but need some help. I removed my glovebox and radio and have everything up to that point unscrewed. Now I'm to the gauge cluster. I have the screws undone, but how do you take the knobs off for the lights and wipers?
1986 K/20, 350/TH400, My First 4x4.......
1969C/10 is offline   Reply With Quote
Old 10-21-2006, 07:47 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Help With Removing Dash Pad
Theres a set screw in the side of the wiper knob and the light switch has a small button on the bottom (I think) of the switch. I usually pull the light switch knob out like you were turning on the lights, push in on the spring loaded button on the switch body and pull the knob out. The knob and shaft come out as one piece.
LockDoc
Leon
Old 10-21-2006, 07:55 PM   #3
Bob Moore
LockDoc is correct. When you pull the headlamp knob out your lights will run down the battery so I recommend disconnecting the cables. I also recommend droping the steering column to ease the cluster removal - very easy to break off a corner of the plastic and/or scratch the paint without doing this.
The pal nuts in the corners are usually the hardest to get a socket on. Just take your time.
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 10-21-2006, 08:42 PM   #4
bad_turbo
turbo enthusiast
bad_turbo's Avatar
WOW! All that work just to take the dash pad off?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting "
bad_turbo is offline   Reply With Quote
Old 10-21-2006, 08:48 PM   #5
1969C/10
Unskilled Labor
1969C/10's Avatar
Yeah, it is a lot of work. I guess I will try to finish removing it tomm. since it is dark out. Thanks for the info LockDoc and Bob Moore.
Old 10-21-2006, 11:06 PM   #6
WTB3
http://67-72chevytrucks.com/vboard/s...32#post1332032
'65 Chevy 1/2 ton Longbed
'71 Chevy 1/2 ton Longbed
WTB3 is offline   Reply With Quote
Old 10-21-2006, 11:27 PM   #7
69TowRig
If you have the dexterity and tools, you do not have to take apart anything on the driver's side to get the pad off. The only thing I removed on my non-AC K5 was the glovebox.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 10-22-2006, 12:20 AM   #8
phlegm
Still Green but learning
phlegm's Avatar
Paneldeland was telling me about this just today at our meet, PM him he can probably give you a tool list and some advice.
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
