10-21-2006, 08:59 PM | #1 |
laying low
gas tank pad
Is there supposed to be a pad between the gas tank and body where it bolts in? If so what's it made of?
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
10-21-2006, 09:42 PM | #2 |
Re: gas tank pad
Yes there is, kind of a thick tar paper, about 1/8 thick. There is one on each side, about 3 by 4 inches. But, if you put in full length carpet, we put the tank on top of the carpet, no addtional pad. I think it is likely there to prevent squeaking/ rubbing between the cab and the tank.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
10-21-2006, 09:50 PM | #3 |
sufficiently talented fool
Re: gas tank pad
You can use roofing tar paper for it as well.
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
10-21-2006, 10:03 PM | #4 |
laying low
Re: gas tank pad
I thought there should be but mine is bare and it's been so long. I'll come up with something to use. Thanks.
10-21-2006, 11:52 PM | #5 |
The Older Generation
Re: gas tank pad
Boog,
I would think a piece of old inner tube would work too. I keep a large piece of old tractor tube around for that kind of use. Nice & heavy. Whatever you use put a little glue on it to hold it in place..... LockDoc
10-22-2006, 12:36 AM | #6 |
Re: gas tank pad
carpet, carpet padding, cardboard, floor mat, tar paper, dynamat...
Id go with dynamat or carpet padding... |
10-22-2006, 12:47 AM | #7 |
Re: gas tank pad
The only downside I can see to the carpet, pad, or cardboard is that it would retain moisture for a long time.... I guess it would work good in the drier climates though.
LockDoc
10-22-2006, 01:32 AM | #8 |
Re: gas tank pad
There is supposed to be two thick tarpaper pads. Some of the vendors sell them. About all they do is keep the tank from squeaking on the cab floor.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
10-22-2006, 02:23 AM | #9 |
Re: gas tank pad
I just reread your post, and you mentioned something about where it bolts in. Just to clarify, there are two pads that go under the tank, between it and the floor at the bottom of the tank, there is nothing used or needed between the bolt locations, tank flange, and the cab.
10-22-2006, 07:44 AM | #10 |
laying low
Re: gas tank pad
Right. I want to head off any potential rattles and squeaks as well as holes rubbed in my tank. thanks guys.
