Garage Queen Material
so what did i break now?
got the temp gauge to start staying a lot steadier and not pegging out when it really wasnt 260+ degrees. i had some air in the system, and now that i got it out, the upper hose stays VERY pressurized while hot.
![]() but, every now and then i will hear this hissing type sound coming from where the heater core is located. my floorboard isnt wet and i cant find a leak anywhere around there, but i'm sure it has something to do with the heater core. |
I'm back with 2nd truck!
Re: so what did i break now?
You might have a vacuum leak there Eric. The hose comes into there to pull the door open and shut when you are sliding the temp selector.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
Chevys Kick A$$
Yeah, I was going to suggest a possible vaccum leak also.
-Lates
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
i'll look under there.
it could be it, but it doesnt sound like a vacuum leak. |
i had a truck do that too....turned out to be that the heater core was plugging up and the hissing that you hear is the antifreeze being forced through where it is plugged
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles ![]() '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L ![]() ![]() ![]() |
Eric get a vacuum tester from Harbor Frieght for like $10 and check the vacuum at a constant source. This will tell you alot about your engine's running and diagnose if it does or doesn't have a leak.
#7 | |
i checked that vacuum line behind the dash, and its all nice and tight, no leaks at all. and i had a vacuum gauge before i moved, but now i dont know where its at ![]() so, i planned on replacing the radiator anyways, might as well replace the heater core too.... ![]() at least my cooling system will be all brand new Last edited by ocbaud; 10-24-2006 at 09:48 AM. |
