Old 10-23-2006, 12:20 AM   #1
orange-c10
hesitation during acceleration
ive got a 70 c-10 with a 350. i had a edelbrock carb on the stock manifold and yesterday i installed a performer intake as well. after messing w/ timing and everything ive got a bad flat spot. idle is good but right off idle it just falls on its face. when i installed the distributor i mixed the two black wires on the coil. i dont know if maybe i fried something or what. truck ran great before i put on the new manifold.
orange-c10 is offline   Reply With Quote
Old 10-23-2006, 03:02 PM   #2
orange-c10
Re: hesitaion during acceleration
bump
Old 10-24-2006, 09:21 PM   #3
casterbuster
Mejor Que Nada
casterbuster's Avatar
sounds like a timing issue to me..
The only thing that separates
"Dreams" from "Reality"
is TIME and MONEY!!!
casterbuster is offline   Reply With Quote
Old 10-24-2006, 10:21 PM   #4
Texasdeere
Texasdeere's Avatar
Is the carburetor new or used? Usually this is a lean condition, such as a bad accelerator pump. Retarded ign timing from stock could cause a flat spot or weak off idle acceleration. Sometimes a weak accell pump can be partially masked by a little more timing advance too.
Texasdeere is offline   Reply With Quote
Old 10-24-2006, 11:39 PM   #5
orange-c10
Re: hesitation during acceleration
brand new carb. i advanced the timing way off the scale and the flat spot went away. still pings when i get on it. should i advance it more??
Old 10-25-2006, 09:34 AM   #6
Texasdeere
Texasdeere's Avatar
I would back off the timing until the pinging stops. The pinging or pre-ingnition is not good for your engine. If the flat spot comes back try just riching up your idle mixture screws a little and see if that helps. Listen to your engine idle when you do this, it will tell you where it likes it. Hopefully as you richin it up your idle will smooth out some meanig that it was too lean before.
Old 10-25-2006, 12:41 PM   #7
A.P.
Black 72 Chevy
A.P.'s Avatar
Orange C-10, check these videos from Edelbrock.
http://www.edelbrock.com/automotive_...ech_vids.shtml
A.P. is offline   Reply With Quote
Old 10-25-2006, 01:09 PM   #8
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Sounds to me like when you pulled the intake and the distributor you put the distributor back in about one tooth off. Check this by putting the timing mark on the balancer on the zero mark on the timing tab and pull the cap off the distributor and see if the rotor button lines up exactly with either no.1 or no.6 spark plug wire. If it doesn't then pull the distributor up just enough to align it. If you wired the coil in reverse polarity it will do exactly as you describe also.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 10-25-2006, 01:43 PM   #9
68C15
blood type; Retumbo
68C15's Avatar
"2 black wires on coil" tells me it is a points setup. polarity is important. the "-" side of coil goes to dist. while the "+" side goes to ign. switch and starter.
when is the last time you set your dwell? IIRC it calls for 28-32* dwell at warm idle.
hope this helps
68C15 is offline   Reply With Quote
Old 10-25-2006, 08:33 PM   #10
orange-c10
deleted the points with one of those accel kits. the coil is wired properly. im going to turn the motor to the 0 mark and check the distributor. maybe i did get it off a little
