10-23-2006, 02:56 PM | #1 |
Oilfield Trash
ebrake cables with 700R4
decided i better get my e brakes working on the shortbox, i need to order new cables, but now with the 700 r4 tranny what cables do i order?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
10-23-2006, 03:23 PM | #2 | |||
Union Electrician
Re: ebrake cables with 700R4
look here and see which ones you need...http://www.maliburacing.com/auto_tranny_id.htm
You can use this a guide
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
10-24-2006, 11:30 PM | #3 |
I can't imagine a trans swap would make any difference in e-brake cable length?
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
10-25-2006, 12:14 AM | #4 |
Questionable
Depends on what kinda trans you're swappin
I am gonna probably need to find a diff't e-brake cable for the truck soon, something that doesn't criss-cross
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
10-25-2006, 12:30 AM | #5 |
This is a good question. One of the things I would like to do to my truck is get the E-brake working again (PO hacked and cut the crap out of it) So I don't know what goes where. Truck was originally a I6 3spd manual... if I use the same set-up as stock will it interfere with my 700R4? (I have a 67 with the handbrake that pinches the skin on your hand if your not careful! )
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-23-2008, 05:21 AM | #6 |
Questionable
I might have an eBrake cable for ya, bud. At least, if you still haven't got it figured out.
Well, I'm going to bump this one again! I'm still wondering - has anyone ever seen a 67-68 (or later) eBrake setup that DOES NOT criss-cross under the body in an "X-shape" like the stock non-pedal (handle e-brake) does? If so, how was it done? I'd like to keep my e-brake handle, because I really like it! But the brake cable setup is rubbing my tranny tailshaft and crossmember, taking the powdercoat and paint right off 'em. Pic of that:
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 02-23-2008 at 05:23 AM. |
02-23-2008, 05:25 AM | #7 |
Questionable
In looking at this, I suppose I could possibly route the e-brake cable through the hole in the tailshaft - it looks almost like it already is in this picture That would keep it off the crossmember....but then it would probably interfere with my exhaust. So, still curious to see some feedback.
02-23-2008, 05:25 AM | #8 |
Old member
I have a stock 1971 brake setup with a 700-R4 trans and have no problems.
02-23-2008, 08:27 AM | #9 |
69-72 crosses the same way. I'm running the 4L60E in a Suburban and Crewcab and have no clearance issues.
Forgot to add, LOKAR sell a real nice setup that will allow you to do away with the metal rods.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-23-2008 at 08:29 AM. |
02-23-2008, 11:51 AM | #10 |
Questionable
Is it designed for our trucks?
02-23-2008, 07:30 PM | #11 |
It's a universal kit that's easy to install. I used one on my 48.
http://www.lokar.com/interior_pages/..._concables.htm
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-23-2008, 08:32 PM | #12 |
Questionable
Got any pics of the install, per chance?
02-23-2008, 09:36 PM | #13 |
02-24-2008, 12:40 AM | #14 |
Questionable
This seems to be what Lokar recommends for a rear drum truck like the 67-72 pickups:
http://www.lokar.com/product-descrip...ake-cables.htm Do these look the same as what you used, Rob?
02-24-2008, 12:45 AM | #15 | |
Licensed to Thrill!
Me too. DLB |
02-24-2008, 06:11 AM | #16 | |
