Old 10-23-2006, 04:52 PM   #1
Blue85
Oilfield Trash
Blue85's Avatar
47-54 guys, what front clip do u use
tryin to get my 52 project underway, whats the best front suspension transplant to use? my buddy has a 84 camaro he is scrapping, told me i could have it for me if i wanted, will it work good? Tryin to steer away from spending 2g on an aftermarket conversion
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 10-23-2006, 04:54 PM   #2
bretcopsey
Re: 47-54 guys, what front clip do u use
Isn't the third gen Camaro frontend strut based? I beleive first gen Camaro and mid seventies G body are about the same track width as the AD truck. First gen Camaro susoension geometry needs work though and is 'rear-steer'
My 51 project
http://www.cardomain.com/ride/2285825
My 68 Camaro project
http://www.cardomain.com/ride/2277404/1
bretcopsey is offline   Reply With Quote
Old 10-23-2006, 05:48 PM   #3
CAL 58 GMC
CAL 58 GMC's Avatar
If your planning on grafting a Camaro sub frame then the best years would be 1970 to 1981 and of those the 1976 to 1981 are preferred for the front steering linkage. Nova sub frames also work well. I would stay away from 1982 and newer, as bretcopsey said, they use McPerson struts and could lead to alot of modifications.
CAL 58 GMC is offline   Reply With Quote
Old 10-24-2006, 03:43 AM   #4
fireout
75 -79 Nova subframes work good.
fireout is offline   Reply With Quote
Old 10-24-2006, 10:01 PM   #5
Kid
Kid's Avatar
If you want to save money, but are willing to spend the labor hours, I suggest a "G" body front clip. (78 to 87 I think) It has the correct width for the 47 to 54 trucks. The camaro cips are too wide by about 3" ovrerall. I am not sure about the nova clips.
I put a 84 "G" body clip on my 51. Here is a link to some pics of the instl. It does involve some labor.
http://67-72chevytrucks.com/vboard/s...d.php?t=154951
Kid is offline   Reply With Quote
Old 10-25-2006, 05:28 PM   #6
cajundragger
if you decide to use a crossmember I recomend the Scotts setup. Thats what I got for my project and its sweet....
cajundragger is offline   Reply With Quote
Old 10-25-2006, 11:12 PM   #7
pgf545
pgf545's Avatar
I did a Heidt's and it wasn't too bad...the only thing I was disappointed with was the instructions.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 10-26-2006, 03:19 PM   #8
Daniel U
Daniel U's Avatar
The 82-92 Firebirds and Camaros(F-bodies) use a K member that bolt to the unibodies. There would difinitely be some mods to make this work! No offense, but don't try to reinvent the wheel.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 10-26-2006, 06:21 PM   #9
Kabwe
Certified Car Nut
Kabwe's Avatar
Monte Carlos are my favorite. Its not as wide as the Camaro which works well in the advance design trucks.
Kabwe is offline   Reply With Quote
Old 11-04-2006, 01:55 PM   #10
Daniel U
Daniel U's Avatar
I just found out mine was clipped with an AMC Pacer. Don't know what year. I'm cutting it off and having a TCI (total cost involved)front end put on for ease of future brake/suspension work. See my thread for details in the future.
Old 11-05-2006, 12:18 PM   #11
chevyrestoguy
chevyrestoguy's Avatar
Definately measure the track width of your truck and any potential donor. If you want to lower your truck, try to find a donor of equal or less track width. I've seen guys use 67-69 Camaro/68-7? Nova, but beware of the rear steer set-up, as it can mess with header selection. 70-81 Camaro is too wide. If I had it to do all over again, I would have saved my money up and did a Mustang II. There are lots of companies who make specific kits for the 48-54 Chevy/GMC. You don't have to cut the front of the frame off, you utilize your stock front bumper mounts, you have disc brakes and rack and pinion steering, and they make everything under the sun to modify and update the stock Mustang stuff. I did a 70 Camaro clip in my '55 (2nd series) and I love it, but it was alot of work and making bumper brackets was a pain in the rear.
________
Ford Ltd
chevyrestoguy is offline   Reply With Quote
