Gone Fishing
Drop spindles rubbin the wheel weights
Has anyone else ever had this problem? I have been hearing a sqeel off and on and decide to check it out. I found that my wheel weights were ground down from the drop spindles. They are ECE spindles and I'm still runin the 15 in ralleys. I guess the noise will quit when they either grind down enough or I have the wheels rebalanced. Just wondered if anyone else has experienced this.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
WHYBYNU when old will do
Re: Drop spindles rubbin the wheel weights
Pull the weights off ! Mine were rubbing after I put my drop spindels on and before I new they were rubbing I ended up cutting a tire. I think the weight got pinched between the bottom of the control arm and the wheel and sliced the side wall like a knife.. YOU HAVE BEEN WARNED !!!! I HOPE THIS HELPS.
JOHN
71 Cheyenne super 2 tone green and white ZZ6 - Th350 4/6 drop 20x8.5 / 20x10 Billet Specialties |
I got mine from gmc paul and I had to use 1/4 inch or 1/2 spacers (cant remember) just so they would spin and once balanced the weights didnt last the ride home. 15inch rallys.
NCStroker
next time you have the wheels rebalanced, ask them to put tape weights on. they function the same without being in the way.
![]() Join Date: Dec 1999
With truck weight on the wheel, take a look. Chances are that its the end of your A-frame around your ball joint that is too close to the wheel. You need to relieve some of this material. Da a little at a time until it moves up and down without rubbing the wheel. Worked with my 8X15 rally wheels. The a-frame sits in a different attitude with the dropped spindle than it does with the stock one. Good luck!
Smitty '71 Short Fleetside Spring Valley, Ca. |
![]() Join Date: Aug 2003
I've had that problem before, but never with ECE spindles.
Questionable
I've heard of this happening with McGaughy's (sp?) spindles, never ECE. I am interested - has anyone ever had this happen with 16" wheels?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
WTB this ad
Yep, ECE spindles will rub with a 15x8 wheel. I have had guys tell me that a 15x7 rally will work with no clearance issues. More than likely you are rubbing the lower control arms. You could always grind off the offending material and then box the bottom of the control arms like the old school hydraulic hopping guys do.
Yup. Been there done that. I am runnin 15x7 wheel vintique vette rallies and western spindles. First time it hit I was runnin about 90 on a curve and the wheel flexed and it sounded like a sledge hammer hit my truck and it was gone. I switched to stick on weights behind the center of the rim and haven't had a problem since. I don't believe 16 inch wheels would pose a problem unless they are really reversed. Its a scary feeling for sure.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80 Nice ride 67 Chevy C-10 LWB Built 350 TH-400 Wifes ride and family rig: 2001 Furd Expedition 5.4 Liter ![]() Kickin back in Rolla,Mo. USA "Do the thing you fear most and the death of fear is certain" Mark Twain |
TOTY 2006
I am running ece spindles with my 15x8 (five lug) ralleys, and no problems with the wheel weights....
![]() Join Date: Jan 2000
I had the same prolem with Mcgaughy spindles but switched to ECE and have no more problems. I'm running 15x8 Vette ralleyes up front
70 Jimmy 4x4 71 GMC 2500 Too bad stupidity isn't painful |
My question to JSB is what width wheels is he running? I am currently mocked up with 15x8 rallys on ECE drop spindles but will probably run 15x6.5 ralleys.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
#13 |
Gone Fishing
They are 15x8
#14 |
Shifty, it's so close to clearing on a 15'' wheel I can't imagine a 16'' would have any problem unless they had some serious backspacing.
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
#15 | |
FWIW, I have Bell Tech 3" spindles on my 74. The lower a-arm lip never rubbed @ all w/15x6.5" van ralleys but they do rub on my 18x8" TT2's. The van ralleys were less than 4"BS & the TT2's are 5.25"BS. I have to use stick on weights or find a really good tire guy that knows how to work the tire on the rim for a zero balance.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-24-2006 at 11:43 PM. |
#16 |
Questionable
I would be really interested to know the rim size (DDxWW) and the backspace/offset of everyone above
#17 |
I've had them scrape the weights on regular truck rally's with 4'' BC.
#18 | |
Response appreciated. Mark
71 Cheyenne SWB |
