Back in the sticks
Tilt column issues...
Well, I got the pin remover tool from the tool store, but wouldn't you know it, it too broke off in the column. And its hardened! Nice. Still unable to get this one pin out. Anyone got any ideas on pulling the pin? Short of the plasma cutter that is....Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Re: Tilt column issues...
I use a slide hammer with a machine screw to pull the really tough pins. I also soak the pins down with penetrant.
I have not run across one that could not be pulled, yet! Jim |
Back in the sticks
I tried the slide hammer thing right off, but not the penetrating fluid. I'll give it a try again as soon as I can get the hardened screw extracted! Thanks, Jeff.
![]() Join Date: Mar 2003
Did you release the spring pressure on the tilt mechanism first
Back in the sticks
Ya, it has no spring pressure, thats why its being rebuilt. Thanks, Jeff.
