Old 04-22-2002, 04:57 PM   #1
mhs
Post Old window tint
What is the best way to remove old window tint so that I can have new put on.
"Success is going from failure to failure without losing your enthusiasm" (Abraham Lincoln)
mhs is offline   Reply With Quote
Old 04-22-2002, 05:25 PM   #2
Low68
Low68's Avatar
Post
I used a utility knife. One that has the long blades. I put it out all the way and bent it so it was parallel with the window and scraped of the tint. Once I got the tint off, I had to use some stuff to get the leftover stickum junk off. It takes a long time, but it works. If you aren't carful, it can scratch up the glass. I used some kind of degreaser/cleaner for when you paint to get the stickum junk off. Good luck
Build Thread
Low68 is offline   Reply With Quote
Old 04-22-2002, 09:34 PM   #3
sub4rvr
sub4rvr's Avatar
Post
use a one sided razor blade and lots of window cleaner.
72 C10 suburban
85 C20
90 S10
69 Torino GT
90 Mustang GT Conv.
Palm Springs, Ca.
72 C10 Suburban
90 S10
57 F100 (2)
67 Mustang (2)
69 Torino GT
00 Mustang GT Conv.
sub4rvr is offline   Reply With Quote
Old 04-22-2002, 09:47 PM   #4
mhs
Post
Thanks, I was hoping for an easier way.
Old 04-22-2002, 11:26 PM   #5
lofly'a
lofly'a's Avatar
Post
go to paint supply store and ask for decal remover. comes in aerosol can, or buy some household ammonia, heat up the glass in the sun or with a heat or blowdryer then scrape it off witha box cutter blade. i clamp the blade with some vise-grips as a holding tool.
keep fly'in lo
66 gto ragtop 389/400
72 blazer (wuza4by)
68 swb fleet 350/700
98 tahoe 2dr (daily ride)
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 04-23-2002, 07:55 AM   #6
mikej71
Unregistered User
mikej71's Avatar
Post
I just removed mine with a hairdryer and a razor blade scraper. The hairdryer was the key. Once I got all of the film off, I squirted it down with windex, and used the scraper again. The glue came off really easy.
71 SWB Stepside
Houston, TX
71 SWB Stepside
SB400/TH350
mikej71 is offline   Reply With Quote
Old 04-23-2002, 09:32 AM   #7
diggin69
Southern but in Ohio!!!!
diggin69's Avatar
Post
Or try going to your local parts store.. they have stuff in a spray bottle just for removing window tint did my truck with it works great... just pull tint off the glue thats left... just spray this stuff on it almosts wipes off...
Diggin69
69 4x4 3/4ton Custom built with 79 frame,& 72 custom 10 1/2 ton, both are long fleetsides. I'm in Ohio,close to dayton & not far from Richmond. rebelryder@hotmail.com
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79
1972 custom-10 half/ton longbed
1980 1/2 ton 4x4 all original 350/350/205 with air
Eaton,Oh
diggin69 is offline   Reply With Quote
Old 04-23-2002, 07:36 PM   #8
Maximum Overdrive
December 21, 2012
Post
I did this a week or two ago. Bought a razor scraper and then just sprayed on windex and scrapped it right off. Went back and sprayed lots of windex and scraped glue right off. Used a new blade for each window. Took about ten minutes a window to do mine.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 04-23-2002, 07:43 PM   #9
LAP
Post
Pull off old tint. Spray it down with 409. Wait 15 minutes. Spray a little bit more and scrape with a razor.
71 C20 Cheyenne
71 K10 SWB Cheyenne
72 C10 Cheyenne
68 50th Longhorn Custom Camper 396 A/C 25 options
71 C20 Cheyenne
71 K10 SWB Cheyenne
72 C10 Cheyenne
Slaughter, La
LAP is offline   Reply With Quote
