guaging interest
OK I went to the swap meet friday and met a guy that lives not too far from me. He has was it left of a '71 cheyenne that was parked in a barn for the last 30 years. Was hit and buckled frame. I just took the A/C, cluster,column(when i get back tomorrow, ran out of day light) and dash pad. There isn't much left, Seat belts seem to be in good shape and are White? in color The seat in there white also but coming apart at the end seams. the back glass is still there. How does the headliner trim come off?? i took out the screws but didn't want to brake em. headliner is molded but there. Can i add teh headliner to my truck if it didn't have it before? the column is non tilt and non tach cluster
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
Re: guaging interest
headliner trim has some tabs on it that snap into slotted holes, tricky to remove without breaking... if you do get it out, you can saw off the tabs and just use the screws and maybe a little adhesive to attach to your roof.
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
There may be adhesive on the head liner as well. There was on my 72. I had to slowly pry it off but it came easily
great thanks guys
To get the headliner trim off without breaking, use 2 hacksaw blades(or something as flexible) to push on each side of the prongs at the same time. Find the trim piece that goes ON last and start there. IIR there are 3 prongs per piece - total 12. Take your time and they won't break.
Good luck - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
