Old 10-23-2006, 10:06 PM   #1
wolfthing2000
Power steering pump
If I remove the pump and the hoses from the Saginaw box, will there be any problems after reassembly?? Is air a problem in the system or just cycle it out by turning the wheel back and forth??????
wolfthing2000 is offline   Reply With Quote
Old 10-23-2006, 10:09 PM   #2
TN4X4
TN4X4's Avatar
Re: Power steering pump
Good question. I'd be interested in this too. I tried the cycle back and forth thing, but my steering at idle is really choppy.
'72 LWB K20 - SOLD
'66 Mustang 289 3spd
'42 Chevrolet Fire Truck
TN4X4 is offline   Reply With Quote
Old 10-23-2006, 11:33 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Check this thread out:
http://67-72chevytrucks.com/vboard/s...power+steering
Especially the last post by bubbagreen
LockDoc
Leon
Old 10-24-2006, 10:57 AM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
If you plan on driving it or not duct tape over the opening to keep dirt out of it. Air wont be a problem its a continuous flow hydraulic system.
sneakysnake is offline   Reply With Quote
Old 10-24-2006, 12:08 PM   #5
wolfthing2000
So if I got it right, I can disconnect, plug holes, re-assemble later and work the air out with wheels jacked up???
Old 10-24-2006, 01:05 PM   #6
sneakysnake
Yes, you dont have to jack it up the air will work it self out after a little bit of driving.You may get a little pump whine at first just recheck your fluid level after a bit.
Old 10-24-2006, 01:22 PM   #7
Aarons72s
I have disconneted mine several times and just reconected. Never had a problem. Worked the same as before I unhooked it.
Aaron
Aarons72s is offline   Reply With Quote
