Old 08-14-2002, 09:31 PM   #1
Question Another Gas Tank Question
Been noticing alot about relocating the gas tank, but as I been checking into this for my 70 SB I notice that most of the kits mention the use of 21 gal Poly tanks. I am not real hip on haveing a plastic bottle for a gas tank...especially in the south here.
Do any of you know someone with a kit that uses a metal tank?
Also I notice on GMC Pauls as with some earlier posts, there was mention of a 31 gal suburban tank that could be used.
I like the idea of the larger tank and was wondering if it will work on a stortbed stepside, or would I be better off sticking with a 21 gal tank?
Old 08-14-2002, 09:55 PM   #2
bigvinnie
bigvinnie's Avatar
I'm using a 19 gallon aluminum tank from No Limit Engineering, easy install and works well with your stock fuel gauge...
http://www.nolimit.net/new.htm
click on "new products"
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 08-15-2002, 09:11 PM   #3
Kas68c10
Kas68c10's Avatar
check the salvage yards, I have a steel one from either a van or an old camaro. I think its too small though, only about 12 gal.
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
