10-24-2006, 11:01 AM | #1 |
TOTY 2006
Have not seen this one before... 4x4 using trailing arms
Hi All,
Here is a new one that I have not seen... Guy converted a 2wd coil spring truck to a 4x4 truck, but kept the rear coils and trailing arms.... I know this is not where to post trucks for sale from other places, but I am more commenting on how he converted it from 2by to 4by... Craigslist ad |
10-24-2006, 11:12 AM | #2 |
Next project: 1970 K10
Re: Have not seen this one before... 4x4 using trailing arms
From the one picture, it looks like the axle is under the trailing arms. Interesting! Can't tell what the two tabs or brackets are that are hanging down inboard from the trailing arms are though.....
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 10-24-2006 at 11:13 AM. |
10-24-2006, 01:47 PM | #3 |
That would be a better ride and the rear axle can articulate a lot more, but if you tweek it enough, the bolt holding the spring on is taking all the brunt!! You can get the axle mount pads new, and just swap left for right and putem under the axle instead of on top, get some lift out of it at the same time. I don't know about turning a good 2wd short bed into 4X4, but to each their own!!
10-24-2006, 01:52 PM | #4 | |
ryan |
10-24-2006, 01:56 PM | #5 |
Panhard bars can only move so much, right? I think I saw on "Extreme 4x4" where they made some adjustable ones....
Looks to be a sharp truck.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 10-24-2006 at 01:57 PM. |
10-24-2006, 02:13 PM | #6 | |
Yeah, but that spring is it. Up and down the panhard doesn't really regulate that but it does on the side to side. It is a great setup and they use it in one form or another in the CORE trucks, it works or he wouldn't be driving it!! |
10-24-2006, 02:36 PM | #7 |
can you say... sand dunes? hehe that would be lotsa fun!!..
10-24-2006, 04:29 PM | #8 |
Location: vacaville ca, because it as far from indy as i can be
petersons did a write up truck about doing this to a 65, but they never finished the truck. the 2 part artcile was more about how to set things up from scratch, put a motor in that not only doesnt belong but with no exsiting referance points, how to setup a custom axle and so on. i wanted to do this to my 65 but i just didnt have the ablity when i had the truck.
10-24-2006, 06:43 PM | #9 |
When I converted my 70 c/10 to 4x4, I installed leaf springs. If I'd have left my old coil springs in, it would have saved a lot of work. I'm sure this is why they left the coils in.
10-24-2006, 06:54 PM | #10 |
Junior Member
In an old issue of 4X4 mag, there was a similar conversion where the rear was mounted under the trailing arms and the front used a chevy axle mated to ford arms with the spring cups, and standard 3/4 ton front springs, using the standard 2 wheel drive crossmember. The set-up looked good and the only major fabrication was a crossmember for the ford arms.
10-24-2006, 07:05 PM | #11 |
The LuvShack Garage
Well, that's different alright
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
10-24-2006, 07:24 PM | #12 | |
graphic designer
10-26-2006, 12:48 AM | #13 | |
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
10-26-2006, 03:02 PM | #14 |
Junior Member
'70,
Can't find the mag, but the diagram shows the basic idea. |
10-26-2006, 07:26 PM | #15 |
Factory 4x4 4-link...right?
Kinda like it, has promise IMO. |
10-26-2006, 08:16 PM | #16 |
Mine was a hevy duty 2wd when I converted it to 4x4 so I already had rear leafs. But in an effort to make it ride better I swaped in the coil set up , using f150 front coils and stock chevy arms with the axle mounted on the bottom, it woked great till I cracked one of the arms. then I made stronger bars and replaced the springs with air bags, now I am back to leafs. the coils and bags sure road better, but with a lifted 4x4 I was woried about blowing a bag on the highway, I think dropping down over a foot would be bad..
10-26-2006, 09:17 PM | #17 |
Cereal Killer
i wouldnt call it a 4 link.......more like triangulated trailing arms and a panhard....i thought about it years ago....but never did anything with the idea....i would think without too much angle in the bars it would work pretty well. cup cars have used them for years so you know the locating strength is there but there not going to really twist like a 4 link would....not that its all that necessary. i think that rear seetup combined with a ford style front radius arm setup you could get some great ride/drive quality.
10-26-2006, 10:21 PM | #18 |
i think the main concern would be adding a swivel joint to the front of the trailing arms as that would be a major stress point. i would also probalby go to a whatts link or 3 link instead of the panhard bar. otherwise i don't see any reason why doing this conversion would be difficult or unrealistic.
as a perk nascar allready uses a swivel joint for there trailing arms. lucky for us they slide right in the bushing sleaves and are somewhat cheap. |
10-27-2006, 05:52 AM | #19 | |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
10-27-2006, 06:25 AM | #20 |
[QUOTE=onetonk5;1845347]i wouldnt call it a 4 link...QUOTE]
but for my short post it worked... |
10-27-2006, 11:01 AM | #21 |
It the new 4wheel mag there is a write on an FJ that has the same thing done to the rear, but hea also added to upper links to trianglulate it and possibly not run a panhard bar.
1969 Chevy Project SWB Fleet, 20s, 5.3, t56, in the weeds. 1970 Chevy Truck cab on a 1979 Jimmy frame-8.1 liter 496 bbc/sm465/np203-jeds doubler-np205/d60/14bff Welded/42 tsls on recentered H1s 1998 Chevy Crew Cab K3500 SAS'd with hpd60, links and swayaway coilovers. 8.1l vortec DD/towrig "I like long walks, especially when they are taken by people who annoy me. " |
05-16-2022, 12:37 AM | #22 |
But Found Her 25yrs Later!
Just googled 4x4 with trailing arms and this thread popped up.
Other than it being odd, what really would be an issue?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
05-16-2022, 01:54 AM | #23 |
An old thread, pretty cool. Thought about this on my project. Would not have used stock trailing arms. The custom Deaver spring packs I chose will work for me and kept cost lower. I started with a rear leaf truck though. Love to see custom mods people do.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
05-16-2022, 07:46 AM | #24 |
Back then I recall seeing a Grapefruit Yellow Suburban converted to 4wd, retaining the coil rear suspension. It was lifted with big tires. That makes two I know of, but none since.
05-16-2022, 02:29 PM | #25 |
BlahBlahBlah
When I brought this up on the 4x4 side a little while back Tim you mentioned that Burb and I was pretty sure I knew the one you were talking about. I searched the board for a long time trying to find it, but Ive never been the greatest at search. I personally like the idea of converting like this. I have a set of cucv ten bolt axels that have been sitting in the barn forever. It keeps me thinking of this swap, but I also think realistically Ill never do it and should just put the axles on Craigslist.
