10-24-2006, 09:10 PM | #1 |
350 hot rod motor
Selling a 260 HP GM crate motor that has had a few extra aftermarket parts added. This motor has about 600 miles on it. It has the GM crate motor shortblock which has 4 bolt main, 2 piece rear seal, nodular iron crankshaft, cast aluminum pistons, 8.5 comp ratio. The factory heads were replaced with Trick Flow "Kenny Duitweiller" heads, Lunati VooDoo cam, Trick Flow roller rockers, Edelbrock RPM intake. The carb is not included it's just to keep trash out of the motor while it's on the stand. Pick up only in Ft Worth. $2300
