Old 08-14-2002, 11:53 PM   #1
Vic1970
Need some serious help... emission system !!!!
I have a 1970 GMC C1500 pickup... with a emmission system that I can't figure out. The canister has three lines coming out of it. The tank and PCV lines I can handle --- it is the one mark air cleaner I can't sort out. It is connected to a metal tube that appears to bolt to the bottom of the passenger side valve cover... and then it connects somewhere. It appears it once connected to the air horn of the air cleaner... I know everyone thinks I'm crazy... I tried to attached some photos but could not make it to happen.. so I will be happy to email you a copy if it will help understand what I'm talking about. I would like to figure out how this monster once went together.... I think I'm missing a hose and a component that fits into the whole on the bottom of the air cleaner.... \
Check every book I can find in four libraries and no luck... can anyone HELP me...
Vic 1970
Vic1970 is offline   Reply With Quote
Old 08-15-2002, 01:32 AM   #2
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
i'm kinda lost here....the only metal tube i can think of that would be in the vicinity of the valve cover is the heat riser for the choke, or possible the vacuum tube for the vacuum modulator.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-15-2002, 01:42 AM   #3
colohusker
here's some pics I resized for vic1970. He can add the explanation tomorrow.
pic 1 - canister
I say it's only money, my wife says it's only a truck....
'71 C10 Deluxe, factory ac, ps, pb, should be done by 2102
Longmont, CO
husker95@hotmail.com
colohusker is offline   Reply With Quote
Old 08-15-2002, 01:43 AM   #4
colohusker
The tube it connects to:
Longmont, CO
Old 08-15-2002, 01:44 AM   #5
colohusker
another view of the tube:
Longmont, CO
Old 08-15-2002, 01:45 AM   #6
colohusker
bottom of the horn on the air cleaner:
Longmont, CO
Old 08-15-2002, 01:46 AM   #7
colohusker
another view of the horn on the air cleaner:
Longmont, CO
Old 08-15-2002, 01:52 AM   #8
colohusker
and here's the canister assembly:
Longmont, CO
Old 08-15-2002, 01:54 AM   #9
O'l Buck
O'l Buck's Avatar
Ok, thanks for the pics Scott.....now i'm not so lost. I've never seen one of those systems working, but I think the tube comming from the canister that says "air cleaner" is supposed to run to a nipple on the breather snorkel which is apparently broke off or was a plastic piece that can be replace......
My thinking on this is it is a vent from the canister and it feeds to the air cleaner to draw the vapors and burn them instead of just venting into the air.
Chad
Old 08-15-2002, 06:26 AM   #10
68 Suburban
68 Suburban's Avatar
Scott, that is an interesting shade of finger nail polish you are wearing!! :p
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 08-15-2002, 08:03 AM   #11
Vic1970
The only one?
Why is it, I get to have the only one in the world...??!!! @%#*
Scott thanks for posting the pictures.
I agree with o'l Buck that the system connects to bottom of the air cleaner... does anyone have a part number? or any idea where I can find one. I have been through all the junk yards in the area with no luck... I think it is an early Calif emission system, even my gas tank is mark "CAL", heck even the carb is different and have not been able to track down anything like it...
Thanks for your help up front...
Vic 1970
Old 08-15-2002, 10:30 AM   #12
colohusker
LOL, isn't it though? Wish I was working on something that clean, but I just resized and posted the pictures, wasn't actually there.
Scott
Longmont, CO
Old 08-15-2002, 10:48 AM   #13
Vic1970
OK OK lets get to the issue
The finger nail polish is very nice on my daughters hands... and yes they are clean...
BUT what about the tube on the engine... LOL... somebody has got to know... right?
Vic 1970
Old 08-15-2002, 12:39 PM   #14
jerry moss
Born Psycho
jerry moss's Avatar
i just checked my 72 that has a canister, one line tees into the pcv, one line to the tank and the third is hooked to a nipple on the side of the carb under the choke pull off. i'm assuming it's correct routing as it passed calif emissions last time we had to smog it and i have not changed anything since then. your canister is different than mine in appearance, mine has three different size hoses and the one hooked to the side of the carb is pretty small. i hope this helps but it probably makes it more confusing.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 08-15-2002, 01:06 PM   #15
Michael A. K. G
Huh??
You never have to smog a '72 in California. Never.
Are you sure you're talking about the same year truck? The emissions systems changed very quickly in the early '70s.
Michael A. K. G is offline   Reply With Quote
Old 08-15-2002, 05:16 PM   #16
jerry moss
Born Psycho
jerry moss's Avatar
Angry
Michael,
re-read my post !!!!!!!!
i know we don't have to smog them now, but there was a time, not too long ago, that we did. we had to smog anything 55 and newer for a while, even though 65 and older never had smog equipment on them. i work in a calif. certified smog shop and have been there for 17 years as a muffler/exhaust person. one thing for you to think about-- the new software we got for our smog machine has everything on it for 66-73s, i doubt they would spend the money to put that information on the updated software if there wasn't plans to use it in the near future.
and FYI--i do know a little about these trucks, i have been in and around them since 1969. in that time i've owned over 200 of them in one form or another.
have a nice day.
jerry moss
Old 08-15-2002, 09:03 PM   #17
Vic1970
Jerry, what do you think the hole in the air cleaner is for? I have looked many and I can find no other air cleaner air horn like it... we have owned the truck (Dad can't remember what was there and he did not drill a hole.
Also, I don't need the tube to run a line to the carb... and I have looked and I can find no connection on the orginal carb or manifold I have.
Tough one but I know that someone out there can tell us....
VIc 1970
Old 08-15-2002, 09:06 PM   #18
Super Chevy
Super Chevy's Avatar
I have the same thing in my 72 chevy, i bypassed it, no emissions for trucks and cars 1975 and below here
Super Chevy is offline   Reply With Quote
Old 08-15-2002, 09:07 PM   #19
jerry moss
Born Psycho
jerry moss's Avatar
Vic,
i've never seen the hole in the end of the air cleaner. hopefully someone here will be able to help. best of luck.
jerry moss
