Old 10-25-2006, 12:29 PM   #1
ilovetara
My truck is in pieces!
ilovetara's Avatar
69 c10 starting problems
Hey all. Having some trouble starting my 69 truck. Has a 292 I6 engine. Last known start: UNKNOWN!
Replaced:
Engine Oil & filter
Distributor Cap and rotor
spark plugs and wires
battery cables
It does crank but does not start.
Starter seems good
Keep draining the battery though when cranking
there is fuel in the carb.
Thought I flooded it but took all the plugs out and did a crank over a couple times to get the fuel out.
Checked electrical and I am getting the right voltage through each connection
**the ignition is apart, so I am just bridging the ignition harness to try to start it. (reasoning is that I don't have a key for the truck and can't seem to get the ignition out of the dash)
Am I missing something else???
Can anyone help?
Scott
69 Chevy C10 Long
Finally down to the frame!
My Build Progress Pics
ilovetara is offline   Reply With Quote
Old 10-25-2006, 12:44 PM   #2
Jayman931
Jayman931's Avatar
Re: 69 c10 starting problems
sounds like no spark...has to be no fuel or no fire...I would guess something with ignition...timing...?? Sorry not alot of help...
Jayman931 is offline   Reply With Quote
Old 10-25-2006, 03:10 PM   #3
ilovetara
ilovetara's Avatar
If I find the TDC would this help?
69 Chevy C10 Long
Old 10-25-2006, 03:33 PM   #4
Jayman931
Jayman931's Avatar
Ok...dumb questions....
Is the gas new? Or has it been in the truck for years?
Have you tried starting it using carb cleaner in the carb?
I am pretty new to "old engines" I had a problem with a fuel pump relay (but I don't think our trucks have them) if its bad would cause a pressure problem...
Old 10-25-2006, 03:44 PM   #5
phlegm
Still Green but learning
phlegm's Avatar
I am green, so if this is a stupid Idea, sorry.
so when you changed/checked the rotor did you change/check teh points too? I had this same problem on the interstate and it turned out my points had popped where you could not see it without pulling them all the way out.
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 10-25-2006, 03:47 PM   #6
birdie
birdie's Avatar
Sounds like you may not have any spark, or your timing could be way off. Pull a spark and see if you have spark, if you have spark then I would check timing. Get #1 cylinder to TDC and check to see if the rotor is pointing at number 1 cylinder. If not then you need to adjust your timing
1946 Chevy ton truck
1972 Chev C30
1975 Scottsdale C10
birdie is offline   Reply With Quote
Old 10-25-2006, 04:07 PM   #7
ilovetara
ilovetara's Avatar
Okay, got #1 at TDC, rotor is pointing at number 1 on cap. The gas is new.
Now beside the crank, there is a plate with lines on it. Used for timing. Where should my crank timing line match up with the plate?
69 Chevy C10 Long
Old 10-25-2006, 07:17 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
<Snip>
Scott
As far as getting the ignition out of the dash, this thread might help you.
http://67-72chevytrucks.com/vboard/s...highlight=lock
LockDoc
Leon
Old 10-25-2006, 07:49 PM   #9
67chevy2wd
67chevy2wd's Avatar
If you did flood it you should really pull all the plugs and dry them out or replace them. (pending on how bad it was flooded) Do like mentioned above, spray some carb cleaner in the carb while cranking and see if it fires or tries. If it does them you know that you are getting spark but no fuel, and if it doesn't try to fire you are not getting spark.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 10-25-2006, 08:07 PM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Try getting an ignition switch and just plug your harness into it.Then use the key to crank it.That way there should be no question that the wiring is connected in the correct order.Try priming the carb with carb cleaner or a very small amount of fuel.It may have a dried out accalerator pump.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-25-2006, 08:24 PM   #11
Steelawork'n
Just hang'n around
Steelawork'n's Avatar
Test the coil. These can go bad from time to time. Use starting fluid and see if it fires.
Driving a '68 Chevy C20 and a '93 Astro Van. Lots and lots of mileage that I deduct each year.
Steelawork'n is offline   Reply With Quote
Old 10-25-2006, 10:54 PM   #12
ilovetara
ilovetara's Avatar
Okay, tested the coil, enough voltage there. Replaced the points today. I am pretty sure there is no spark. With a spark plug out attached to the wire, no spark when cranking it over.
I will pickup some carb cleaner tomorrow.
Already took the plugs out and cleaned them off.
The truck cranks over really good with the new battery. BUT does not start
Any other suggestions???
69 Chevy C10 Long
Old 10-25-2006, 11:19 PM   #13
Jerry Jones
Happy Camper
Jerry Jones's Avatar
if your coil is outputting coreectly as you say and you hav no spark at the plug... I would look really close at the points.
RIP El Jay! Love you brother!
Jerry Jones is offline   Reply With Quote
Old 10-25-2006, 11:53 PM   #14
GMCMAX
Active Member
GMCMAX's Avatar
Spark plug out attached to wire still won't spark if it isn't grounded, I would check the button of the dist cap that touches the rotor and see if it is ok.
I've got a bad new one before.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 10-26-2006, 03:03 PM   #15
ilovetara
ilovetara's Avatar
Okay picked up some starting fluid, No Help. Adjusted the points, No Help. Man this truck wants to start, but can't seem to get a spark. Could it be the condenser under the distributor cap??
Now when testing the coil, how many volts shoud be showing?
Would there be anything else that I am missing?
69 Chevy C10 Long
Old 10-26-2006, 06:47 PM   #16
Jayman931
Jayman931's Avatar
Hope you got yours started....so i have some hope...mine won't friggin start...its a 69 LWB too....lol...crazy....a little different problem than yours though...
Old 10-26-2006, 07:09 PM   #17
alblogg
alblogg's Avatar
Replaced:
Engine Oil & filter
battery cables
Starter seems good
Can anyone help?
Scott
Are you sure that when you are bridging the ignition you are doing it right and you are getting fire to your points. The best way is to run a wire from your pos battery post to the pos terminal on the coil.
'07 G6 Wife's car
'00 Malibu stock, just a parts getter.
'99 Blazer LT Loaded, K&N Filter, Pioneer Super
Tuner,Viper
'88 K1500 Cheyenne, 5.0, stock, bought new
'86 Nissan 720 Trash Truck
'69 C/10 step side, 307, all original, second owner, in process of restore.
The person who says it cannot be done should not interrurt the person doing it.
Share your knowledge. It is a way to achieve immortality.
Allen- Paintman
Wrenchtwister
Broompusher
alblogg is offline   Reply With Quote
Old 10-26-2006, 08:04 PM   #18
ilovetara
ilovetara's Avatar
Umm let me clarify what I am doing. The ignition harness: I am using a wire and basically hot wiring the truck. Should I be putting a wire on the pos battery to the pos coil instead???
69 Chevy C10 Long
Old 10-26-2006, 11:45 PM   #19
ilovetara
ilovetara's Avatar
Okay, update. Bought a new condenser... still no luck. Man loosing hope here. Could it be the coil? Can someone tell me how to test it.
Thanks for everyones help
Scott
69 Chevy C10 Long
Old 10-26-2006, 11:55 PM   #20
84_4x4
84_4x4's Avatar
to test spark correctly take a screw driver shove it in the boot and hold 1/8th of an inch to ground (not carb (fire)) the have someone crank the engine over you should see spark if not then you are not getting spark.
if your not getting spark make sure your coil had a good ground you can check your coil with a volt/ohm meter like picture below
84_4x4 is offline   Reply With Quote
Old 10-27-2006, 06:47 AM   #21
curbyk
69 C-10 project
curbyk's Avatar
A couple of people may have hit on your problem...get a new ignition switch and plug it in to the ignition harness (you can change it out with the one in the dash later)...I believe using a wire to jump the ignition at the harness can allow the engine to crank over and still not power the points/coil hence no spark. alblogg's suggestion will overcome this if it is the problem. I'm sure someone will chime in if this is not correct.
69 C-10 Work is complete
curbyk is offline   Reply With Quote
Old 10-27-2006, 07:19 AM   #22
Werewolf
Woof?
Werewolf's Avatar
Stupid question. Did you adjust your points accordingly? I've come across a couple of people over time who didn't know that they need adjustment. They threw them in their classic cars, didn't set the gap, and wondered why the cars wouldn't run.
1968 LWB CST BB
2004 Avalanche Z71 LT3.
2003 S-10 ZR2 (hers).
1997 Astro
1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck.
1997 Saturn - need gas mileage from something!
Werewolf is offline   Reply With Quote
Old 10-27-2006, 07:31 AM   #23
mrein3
mrein3's Avatar
IIRC, You need to get 12 volts to TWO wires behind the ignition switch. One to the starter and one to the ignition. It sounds to me like all you are doing is putting 12 volts to the starter. Then when you let off the starter there is nothing "on".
Does that make sense?
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 10-27-2006, 04:42 PM   #24
ilovetara
ilovetara's Avatar
Yes that may be. All I am doing is using a piece of wire and putting one end into the red and one in the purple (I think those colors) Does anyone know what other color of wire needs 12V??
69 Chevy C10 Long
Old 10-27-2006, 04:45 PM   #25
ilovetara
ilovetara's Avatar
As far as the ignition in the dash. I have no key for it, sooo how would I possibly get the ignition apart and out??
69 Chevy C10 Long
