Old 10-25-2006, 07:30 PM   #1
jtm
jtm's Avatar
tail lights on 64 driving me insane
ok...replaced rear harness that goes to the tail lights and the license plate light. license plate light works but tail lights do not...replaced fuse and bulbs, still nothing...what the hell am i missing?
wherever you go...there you are...
jtm is offline   Reply With Quote
Old 10-25-2006, 08:09 PM   #2
iride
Re: tail lights on 64 driving me insane
sounds like a ground problem make sure the housing is grounded where the screws are it is usually rusty and doesn't ground, if you have to, run a good ground to the light housing with a piece of wire
iride is offline   Reply With Quote
Old 10-25-2006, 08:26 PM   #3
jtm
jtm's Avatar
thanks, gonna go try it, never even thought the housing would need to be grounded....
Old 10-25-2006, 08:38 PM   #4
jtm
jtm's Avatar
holy schnikys batman....where do your live...bringing you a six pack of your choice...all i did was put a clean screw in and voila!!!!!
i am such a neophyte...guess thats how you learn though....thanks a bunch for the tip....
Old 10-25-2006, 09:47 PM   #5
jtm
jtm's Avatar
everything working cept now no brake lights...something to look forward to tomorrow
Old 10-26-2006, 01:12 AM   #6
Hilandr451
Hilandr451's Avatar
Re: Brake lights
check your turn signals & see if they work. If the emergency flasher is broken or missing neither the turn signals nor the brake lights will work.
Greg Smith a.k.a. "The Highlander"
1966 C20 Custom Camper, 2017 Chevy Silverado 1500
Highlander's Project Pics
Highlander's web site: www.6066ChevyTrucks.com
Hilandr451 is offline   Reply With Quote
Old 10-27-2006, 08:23 AM   #7
pheengurs
pheengurs's Avatar
on my 64, I had to rewire new grounds from the battery to the front frame, from the front frame to the inner cab and from the rear frame to each tail light housing...
also my own truck, as far as the 'custom' wiring jobs of many many folks since 64... In a nutshell -- everything that I saw had a groundwire, got a new wire, and a new, clean ground contact point... Everything works as it should now...
1964 K10 shortbox Stepside
383 sbc stroker under vortec heads
sm420 trans / t221 tcase / corp 10 front axle / corp 12 rear axle / 3.73 gears
rolling on 33x12x15 tires on 6 lug rims.
pheengurs is offline   Reply With Quote
Old 10-27-2006, 08:41 AM   #8
Demmit_Hemmit's 65
Demmit_Hemmit's 65's Avatar
Yep............In these old trucks grounds are important..........Had the same problems with my burb.................Fixed the parking lights with a ground...............had to replace the turnsignal switch to fix the brake light problem..................A current tester was a very handy thing to have to figure all this out...........good-luck.................Hemmit
Demmit_Hemmit's 65 is offline   Reply With Quote
Old 10-28-2006, 01:43 AM   #9
jtm
jtm's Avatar
brakes was a disconnected wire...everything working now...thanks guys
