Old 10-25-2006, 09:18 PM   #1
msgross
msgross's Avatar
ACCEL 8mm Super Stock Spiral Core Wire Set V8 Chevy $35 obo Lebanon,PA
Sold to trlrider77, thanks..
SUPERSTOCK SPIRAL
Applications: Late model car & truck coverage
Features: Color-matched silicone spark plug boots, high gloss blue,
black, red & yellow wire, stainless steel spark plug terminals
Benefits: True performance upgrade, increased ignition energy due to
lower resistance, oversized upgrade where OE is 7mm
Construction: 7mm & 8mm, 550° F double silicone construction with a
fiberglass braid
Core: Spiral wound stainless steel alloy conductor, magnetic
suppression & semi-reactive material, fiberglass/Kevlar core,
500 Ohms per foot resistance
This is for a very slightly used set of ACCEL super stock spiral core spark plug wires 8mm and Red. I put these on my 327 SBC expecting to add headers but have decided to stay with my ramhorn manifolds. I now need a new set that runs under the manifold. These should fit any SBC that has headers or a different manifolds that allow "over the valve cover" wires, ramhorns don't. These were about $55 and have about 30 minutes of total run time on them. No burns, rubs or kinks. They are for an HEI setup because thay don't have a short wire for an external coil. Great chance to get a great set of wires for less than MSRP. The spiral core have the extra shielding to prevent electrical feedback that can often be heard in your radio. Thanks...
Last edited by msgross; 10-25-2006 at 10:36 PM. Reason: Sold to trlrider77, thanks..
msgross is offline   Reply With Quote
Old 10-25-2006, 09:24 PM   #2
67sss
67sss's Avatar
Re: ACCEL 8mm Super Stock Spiral Core Wire Set V8 Chevy $35 obo Lebanon,PA
$35 shipped to me and I'll take 'em....
67sss is offline   Reply With Quote
Old 10-25-2006, 09:29 PM   #3
msgross
msgross's Avatar
Do $40 shipped and they will be in the mail before the weekend. These are as new as you can get without going to the store. Or $50 shipped and i'll throw in the new moroso loom kit for them.
Old 10-25-2006, 09:51 PM   #4
67sss
67sss's Avatar
I usually make my own, and I have plenty of looms. So let someone else take a shot at 'em. Thanks anyway and good luck.
Old 10-25-2006, 10:17 PM   #5
trlrider77
Out of money
trlrider77's Avatar
I am interested in the wires and loom. Could you take 45 shipped for both?
trlrider77 is offline   Reply With Quote
Old 10-25-2006, 10:23 PM   #6
msgross
msgross's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=214326 is the wire loom kit. Will work and look great on headers but not so well with ramhorns. Might work with other years of manifolds but not sure. They hook up under the valve cover bolts. Neither of them have seen the road and the wires have only been run for 30 minutes max!
Old 10-25-2006, 10:30 PM   #7
trlrider77
Out of money
trlrider77's Avatar
I'll take them both for $50 shipped.
Old 10-25-2006, 10:35 PM   #8
msgross
msgross's Avatar
