Fuel Gauge Problem?
Tank is full but gauge reads empty.Previous owner installed a new tank.When I disconnect the brown wire out of the fuse block the gauge jumps up past the full mark.Any suggestions?
SKINNY TIRES RULE!
Re: Fuel Gauge Problem?
Sounds like you might need a new sending unit. I found this "fuel system cleaner" at the auto parts store that claims it will clean the sending unit and remove the tarnish. You might give some of this stuff a chance before dropping the tank.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Thanks for the advice. Just got the truck a few weeks ago a few kinks to work out.Here is a picture I took a couple a days ago.
Designated A-hole!
Looks like it's in good shape.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
SKINNY TIRES RULE!
Wow, it looks good. Did you get it up in BC? It looks like it has very little rust, especially for up here in the great wet north.
I found it on craigslist in washington.A few rust issues but over all in pretty good shape.
Sounds like your tan wire from fuse panel to tank is grounded. The gauge is working right because when you disconnect it ,it should go to full or beyond. Leave it disconnected at panel and use a jumber wire from fuse panel and touch other end to ground. Needle should move toward empty. If it does check the tan wire to tank.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
I grounded the fuse panel ,gauge went to empty. Tan wire to tank looks fine. Tank is the black poly type. Might be my sending unit. What do you think?
Check your ground wire from tank that's bolted to frame might not be grounded enough,had this problem with my burb.Hope this helps,Randy
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
The float on mine had pin-hole leak and it sunk to the bottom of the tank. Pull the tank and sweep the sender to check it versus the gauge. Most times if you have the patience the sender can be refurbished in an hour or so. I actually repaired mine, it had a broken wire and bad connections all over it. Save your $$$.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
If tank is "poly" that means the tank is not grounded. Take a wire and attach it to the metal of the sending unit and then ground the other end to the frame.
The Blazer King
That was my problem too.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
#13 |
My ground wire is attached to the frame. It looks like it is going to the sending unit, it is hard to tell without dropping the tank.It's a tough call i might have to drop the tank if I can't figure this out.
#14 |
#15 |
Post Whore
![]() Join Date: Feb 2000
Great looking K5 - welcome to the board. Hope you get the issue resolved easily.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#16 |
Dropped the tank today and took the sending unit out. Sending unit had come apart ,I put it back together and it works fine.A cheap fix lucky for me!
#17 |
SWEET! Always pays to investigate before buying new parts.
