Old 08-15-2002, 02:21 AM   #1
BUXMAN66
go bucks!
cab mount bolts?
going to replace my cab mount rubber bushings,was wonderin if the nut of the bolt is accessible from bottom or from floor pan inside cab.thanks!
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 08-15-2002, 02:29 AM   #2
fine69
fine69's Avatar
Hey. You can access the nut from underneath the truck. But when they put the bolts in the floor at the factory they welded a small spot to keep it from turning. Therefor it is hard to remove the bolt. You could remove the bolt by grinding the weld off. That would be easier than lifting the whole cab up.
The rear bolts just thread up into the cab. There is a nut inside a cage behind the gastank that will not come out. It moves a little, but stays there and the bolt should come out easy.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 08-15-2002, 09:22 AM   #3
A.K.
CAB MOUNTS
I took a dremel tool with one of those flat cutting wheels(removed the nut first) and cut the weld just in front of the where the bolt is welded to the pan. I then tapped out the bolt. To install the new bolt, ground the one flat on the bolt head that is going to be seated where you cut the weld. You need to grind a little at a time til you get it to match. Once you get it to match, it should fit right in place and should be able to torgue down the bolt without it turning. Be sure to where safety glasses when using those little grinding wheels because they won't take any sideloading and will fly into pieces if your not meticulous with them.
A.K. is offline   Reply With Quote
Old 08-15-2002, 10:41 AM   #4
jostrans68
Jostrans68
jostrans68's Avatar
That is weird when I pulled my cabthe 1st time it was not welded and we are the original owners . So i know they have never been touched..................Hmmmmmmmmmmm
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
Old 08-16-2002, 01:43 AM   #5
BUXMAN66
go bucks!
thanks, you guys for the info.will prolly start it this wkend.glad josh decided to respond to my numerous requests to give me my password,i've missed the opprotunity to get some of you guy's knowledge of these trucks!good to hear from ya mike!(aka fine69)later!
