Old 10-26-2006, 06:19 PM   #1
magnethead
7000 #'s of american IRON
magnethead's Avatar
HB switch options?
What were the alternative mounting locations for the high beam headlight switch, other than the far front left corner of the cab, before it was stuck on the steering column?
magnethead is offline   Reply With Quote
Old 10-26-2006, 06:43 PM   #2
hiway
Mad Scientist
Re: HB switch options?
I think that's it. Guess you could go to a newer model colum....post 81.
Everythang relates to Beer!
86 1/2ton on tons! sbc/465/208/D60/14/35's
81 Postal....with 468 bbc
97 Merc Marq comuter
07 Suburban
02 Danger Ranger
hiway is offline   Reply With Quote
Old 10-26-2006, 08:38 PM   #3
magnethead
magnethead's Avatar
the wiring doesn't match up because of wipers and everything.
where was the switch put on trucks with manual tranny's? Surely not underneath the clutch pedal?
Old 10-27-2006, 07:12 PM   #4
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
The late-40s/early-50s trucks and the sixties trucks with standard trans had the dimmer switch located on the upper left side of the floorboard. They were not directly underneath the clutch pedal. BTW, the wire feeding the dimmer switch should be coming from the headlight switch.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
