10-26-2006, 06:28 PM | #1 |
from Colorado (sorry kinda long)
Hi from Colorado.
ok I guess i'll give some back ground on me. At 18 my dad gave me a 71 chevy lwb with a 250/4 speed 2wd. It had alot of cancer issues! the floor board under the gas tank was gone! just a big hole! Both sides of the floor board had pretty bad rust as did the rockers, cab corners(weren't there),wheel wells and the wood bed floor was original and rotted. After driving the truck for a couple years the clutch went out and not really wanting a manual anyway it was traded for a powerglide I had laying around from another project. The pg didn't last long and was replaced with a th350. A few months later the 250 started smoking alittle so I found and rebuilt a 67 327 with 305 heads, flat top pistons,performer intake,cam and carb. Ashamed to admit the body was full of bondo but "looked" straight. When I was 19 my dad picked up a 69 lwb. The body was super clean! The interior was pretty gutted but rust free. When he bought it, it had a "fresh"350/350 in it. Well two weeks after he bought it the motor started blowing white creamy fluid out of the breather in the valvecover!?! You guessed it, the 350 was" fresh" a couple hundred thousand miles before! Number one cylinder had ruptured (you could touch the piston from the lifter valley) into the lifter valley. Disgusted and extremely upset about it he parked it in the back yard. I offered to buy it from several times to receive a look like I was about to be killed, so since he refused to even talk about it I dropped the subject. Eventually dad got tired of it sittin so he told me he'd sell it to me for what he paid(1200.00)! SCORE! But when it came time to pay him he told me to forget about it and just take it! DOUBLE SCORE! A complete disassemble ensued along with alot of stuff found that wasn't known about! All the sheet metal was inded rust free but the frame several inches in front of the front cab mount had been welded (hacked) back together, all the wireing had been butchered, and the tranny mount had been welded to the frame. After much dliberation it was decided to use a 75 camero subframe I had in storage to replace the front of the frame. The camero sub frame if cut properly will slide over the truck frame! After doing the front of the frame and painting it ,,,,,,,,,,,,,,,,,,,,, I found out my first son was on the way! the truck came to a screeching halt and sat for 2 years. During the 2 year break I had seen an 70 extended cab and loved it. So I found another cab cut both apart and started putting them together. About 2/3 of the way through the cab guess what I found out,,,,,,,,,,,, 2 things,,,, 1. stretching a truck cab is a boat load of work,,,and 2. my second son was on the way,,,,,,,,,,,, and again the truck came to screeching halt. Well 7 years later I am starting to work on my truck again. I have found out the cab is screwed after a heavy snow dropped a huge branch on it and trashed the whole thing. On a good note I hadn't stretched the frame yet, and I found a 70 lwb locally for $350.00 so things can start to progress as a 70 instead of a 69. At this point this is the plan,,,, the front end will flip with a normally functioning hood, suicide the doors, tilt bed with a solid cover opening normally, shave the body (the bed and fenders are already done), 1 piece windows, I've seen ALOT of great trucks and projects on here, not all I would do but great work none the less. Thanks for having the site available. Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
10-26-2006, 06:54 PM | #2 |
Just here to help
Re: from Colorado (sorry kinda long)
Welcome to the board from Missouri and thanx for joining
10-26-2006, 07:35 PM | #3 |
Next project: 1970 K10
Welcome to the board Frank! Where in Colorado are you? I am in the Fort Collins area, and there are several of us on here in Northern Colorado, a bunch in the metro area, and some in the Springs and Pueblo area too.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
10-26-2006, 08:51 PM | #4 |
PROJECT 7DEUCE
Welcome to the board from southern oregon..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
10-26-2006, 10:22 PM | #5 |
I'm in colorado springs. I've seen a couple people from colorado on here but seemed like they were way north.
10-26-2006, 10:28 PM | #6 |
Well, we are only about 2 hours apart then. Hopefully some day we can have a big get-together in the Denver area. Maybe at ChevyDude's new shop!!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 10-26-2006 at 10:28 PM. |
10-26-2006, 11:22 PM | #7 |
Gone Fishing
wELCOME TO THE BOARD FROM tEXAS
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
10-27-2006, 01:36 AM | #8 |
Its always something!
Welcome from FT Worth TX.
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed Member of the patina club |
10-27-2006, 03:20 AM | #9 |
Designated A-hole!
Welcome to the board from south Mississippi!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
10-27-2006, 06:00 PM | #10 |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Welcome To The Boards From The Great White North!
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
10-27-2006, 09:03 PM | #11 |
The LuvShack Garage
From West TN
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
10-29-2006, 09:54 PM | #12 |
Post Whore
to the board from KY!
Drew '71 Chevy 350/TH350 Hugger Orange Currently just a rolling frame, body work soon to follow!!! Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927 Daily Driver: 1997 Chevrolet S-10 with more gears than pistons |
10-31-2006, 05:27 AM | #13 |
Welcome to the board!
Classic Trucks Link http://www.classictrucks.com/feature...uck/index.html 1958 GMC.Project Build http://67-72chevytrucks.com/vboard/s...d.php?t=162816 1966 Chevelle Build http://67-72chevytrucks.com/vboard/s...d.php?t=443576 Video http://www.youtube.com/watch?v=prrNKo8F7Zw#GU5U2spHI_4 |
11-05-2006, 11:41 PM | #14 |
RIP Mr Ron
Welcome from West Tennessee.
Ron (Mr Round Tuit) Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
