Old 10-26-2006, 08:55 PM   #1
magnethead
7000 #'s of american IRON
magnethead's Avatar
Trying to make a nice big tech file....
I'm trying to gather some info on my truck. I have no RPO stickers or anything left, so i have no clue what it had factory.
Would anyone happen to have the numbers for a factory 1977 454, casting number T0114TSD? The T means tall deck right (truck motor/HO motor?)?
I know the power specs are
454 - 245 hp @ 3800 rpm - 365 ft.lbs torque @ 2800 rpm
454HD - 240 HP @ 3800 rpm - 370 ft. lbs torque @ 2800 rpm
I'd like to know the specs of the stock cam (i'm assuming i have the stock cam) and all that good stuff, plus the CFM of the quadrajet sitting on top, please, if anyone would happen to have that information at hand. I'd like to hope it's a 4 bolt main.
Also, there's a hole in the transmission hump that's covered by 6 carrage bolts and a piece of sheet metal, but no evidence of a manual transmission ever being on the truck. Could it have possibly been for a hurst or similar truck shifter?
For the longest time my dad has considered swapping an aluminum edelbrock dual plane performer intake with a 650 CFM performer carb, and at one point considered an RV/4x4 cam for the torque plot, but isn't so sure the valvetrain, as worn as it is, would hold up to something like that. Keep in mind it currenly has 1 7/8" headers going to a 3" flange with an H pipe, stock (i think) mufflers, no smog equip, and dual's.
Input?
magnethead is offline   Reply With Quote
Old 10-27-2006, 12:48 AM   #2
84 400
Sb 400 club
84 400's Avatar
Re: Trying to make a nice big tech file....
I like the idea on the edelbrok stuff would make for more towing power! But a valve job would be in order too. I wish i had input for you but am not really sure i can add anything. also it probibly had the shifter as you said as if it had a manual it would be noticable. A manual in that truck would be sweet though nothing like shifting your own.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 12-03-2006, 10:41 PM   #3
magnethead
magnethead's Avatar
Ressurecting an ancient post, I know, but just went on Jeff's site, and delved deeper than I knew existed... I don't have any ID sheets or anything left on my truck, but based off what's on it, I compiled this list...
ha, found more stuff out about my truck.... Gotta love the internet
Engine code:
T0114TSD: Engine Cast In Buffalo, New York Engine plant on The 14th day of January 1977.
The Suffix Code TSD = 1977 Truck 454 CID 250 HP 350 Ft-Lbs
This means my truck is numbers matching, confirming the engine has 350,000 origional miles.
VIN:
TCS347B529252
T- GMC
C- 2 wheel drive
S- 454 4bbl V8
3- 3500 1 ton
4- pickup
7- 1977
B- Balitmore, Maryland Assembly Plant
529252- Serial Number
AS3: Crew Cab
A28: Sliding Rear Window
A52: Bench Seats
C6P: HEady Duty Chassis
C91: Dome Lamp
DF2: Camper Mirrors
E63- Fleetside
F58: Heavy Duty Stabilizer Bar, front
GT5: 4.10 Axle Ratio
G51: Extra Capacity Rear Suspension
J55: Hydroboost Braking System
KC4: Engine Oil Cooler
K34: Cruise Control
LE8: 454 cid motor
M40: TH400
NL2: Dual Fuel Tanks
N33: Stilt Steering Wheel
N41: Power Steering
R05: Dually (10,000 Pound Capacity)
UN3: Radio
U01: Lamp marker Lights
U37: Cigarette Lighter
U58: Stereo Radio
U76: Windshield Antenna
VF1: Chrome Rear Bumper
V01: Heavy Duty Radiator
V02: Heady Duty Transmission Cooler
V37: Chrome Front Bumper
V76: Towing Package
ZY2: Two-tone paint
Z81: Camper Special
Was not Emmisions equipped from Factory
