carb question
my 67 c10 died today. it has the 250 L6. it would only run when pouring gas down the carb which makes me think the carb is clogged. we had to park it on the side of the road so i want to get this done asap. i've been looking and it has the carter yf carb (correct me if i am wrong). please give any advise on what you think it is and how to fix it.
thanks, chris |
Black 72 Chevy
Re: carb question
Could it be the fuel pump that died?
Re: carb question
i would deffinatly check fuel pump and fuel filter this does not sound like a carb problem
Re: carb question
i could took the line off and could feel suction so i didnt think it would bw the pump. i'll definatly check that out though. also the fule filter. thanks for the replies
Re: carb question
If there is a split in the rubber somewhere it will do that. If the rubber is old, replace it.
Woof?
Re: carb question
Pull off the fuel line and crank the truck a bit. Just be careful where you aim that line. If fuel pours out of the line when cranking the truck, then it's not the fuel pump. Like I said, just be careful!
1968 LWB CST BB 2004 Avalanche Z71 LT3. 2003 S-10 ZR2 (hers). 1997 Astro 1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck. 1997 Saturn - need gas mileage from something! |
Re: carb question
well i rebuilt the carb. and it does look like the fuel pump. i got one coming in tomorrow hopfully thats it.
Re: carb question
Re: carb question
check to make sure your getting gas to the fuel pump, if your gas tank is old it might be clogged at the outlet. this is an on going prob. on my 70 dodge... just my .02
Re: carb question
Checj your tank for trash and varnish. That's what killed my 6.
Re: carb question
just got the fuel pump in. runs decent considering the condition it's in. the idle was real high but a turn of a few screws will change that. thanks for the help.
