10-27-2006, 01:13 AM | #1 |
Hood Issues
I thought that the problem in the picture was caused by a bad hood lever or spring so I repleced it with a new one and I have the same problem. Anyone know how I can fix it? Pic says it all.. Ignore that paint job that one is down the road a ways LOL
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
10-27-2006, 01:54 AM | #2 |
BlahBlahBlah
Re: Hood Issues
Looks like its time for new hood hinges. I think at the pivot points they elongate or something along those lines.
10-27-2006, 02:00 AM | #3 |
Re: Hood Issues
mounts too high, loosen bolts, lower, re torque. call it good. dont go and buy new stuff. like smart one up there ^^^
10-27-2006, 02:01 AM | #4 |
BlahBlahBlah
Re: Hood Issues
Well I had to buy a new set because mine were wore out like i stated. I would definatly try your way first. Always nice to save some cash.
10-27-2006, 08:50 AM | #5 |
Re: Hood Issues
Before you go buying new hinges etc. do this simple adjustment-----then let us know how well it works.
REAR HOOD HEIGHT ADJUSTMENT ---by Huck! 1- Loosen the 6 (3 on each side) hinge to fender bolts (9/16ths socket). 2- With the hood open---push it up further till you feel some resistance like it is as far as it should go with no extra stress. 3- Now with the 6 bolts just a little snug---push the front of the hood up a bit more to pre-load the springs---and with it held up like this---/---tighten the six hinge bolts. 4- BEFORE CLOSING THE HOOD, CAREFULLY CHECK FOR ALIGNMENT OF THE HOOD TO THE FIREWALL COWL--THIS SOMETIMES CASUES A BIND SO CHECK IT OUT FIRST. 5- Assuming the hood is now coming down in the rear like you want, adjust the hood front to rear using the 4 bolts (2 on each side) that mount the hood to the hinges 'IF NECESSARY'. 6- You may need to tweek the hood hinge adjustment a bit but in just about every case I've seen, this adjustment process fixes the problem without having to buy new hinges. If the hinges are worn real bad, then you will need new ones but----just make sure the old ones are well lubricated at there multiple pivot points and you may be home free!!!! Let us know---Huck |
10-27-2006, 09:11 AM | #6 |
Re: Hood Issues
yeah try what he said and while your at it spray the crap out of the pivot points with your favorite lubricant/ and spray latch too and throttle linkage and heater control cable and&&&&&&&&&
10-27-2006, 09:35 AM | #7 | |
Licensed to Thrill!
Re: Hood Issues
My favorite is Tri-Flow. I did this a couple of weeks ago and it seems to have remedied my problem - along with my hood getting harder to open. And I know that my hinges are wore - they have visible slop in them. But, some good ole lubin' can go a long ways I suppose. |
10-27-2006, 10:21 AM | #8 |
Re: Hood Issues
Thanks for the tips. I will try them later today and post back. Hood hinges are new forgot to put that in the original post.
10-27-2006, 06:05 PM | #9 |
Re: Hood Issues
Huck I did what you said there and got almost all of it out. Im happy where it is now. Could be that I warped the hood when we dropped it on its side when we did the engine swap.
10-28-2006, 01:51 AM | #10 |
Re: Hood Issues
i dont mean to steal the thread in anyway but anybody know how to fix it if the hood doesnt pop up when you lift the lever is it the hinges or something else and i should probly mention i did take the hood off and the hinges also it used to do it before i took it off but not now
-steven
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
10-28-2006, 11:34 AM | #11 |
Re: Hood Issues
New rubber bumpers on the fenders will make the hood pop up when you open it, be aware that many aftermarket side bumpers are way too thick. I have found the the ones from LMC fit great, they are the right size but cost 3 dollars each, the cheap ones that don't fit are 4 dollars for a set.
Also, if you get an aftermarket cowl seal it will hold the back hood up, it has too much of an "L" shape and will not fold down, you can cut it down too clear or you can still get the correct new one from GM for not much more money and it will fold down when the hood shuts.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 10-28-2006 at 11:38 AM. |
10-28-2006, 08:28 PM | #12 |
Re: Hood Issues
Green Machine, I think you are right about the cowl seal. I replaced mine and it is holding the back of the hood up even after I did the hinge adjustments that Huck suggested. Think I will take it off and do some trimming.
10-29-2006, 08:23 PM | #13 |
Re: Hood Issues
This is why I like this site....
I was just checkin things out and relized I found an answer to a problem I was having but hadn't taken the time to fix. Went out to my garage and fixed my hood. Way cool... Thanx guys!
The Fastor Pastor '68 swb, 447 BBC/ 6-71 Weiand, Dual 950 Bigs Carbs/ 2 1/2" Header tubes - 4" collectors/ M-21 4speed: '70 swb; TH-400 - bagged & shaved. Looking for new engine or parts. Wife - Original {A Real Classic!} |
10-30-2006, 02:42 AM | #14 |
Re: Hood Issues
Huck
Tried your method on the 68 today , worked awesome . I can't believe i had never tried that before . Tks ........................................................ 409
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
10-30-2006, 08:51 AM | #15 |
Re: Hood Issues
Depending on how much upward pressure you apply to pre load the hinge springs, you can usually crush even the newest cowl to hood seal with no difficulty. Just take your time and it should come out fine. (:>)
