1970 C10 Problems
I have a 1970 C10. Everything is stock except that I had dual exhaust put on it about a year ago. I am working on restoring it and have changed all of the hoses, belts, and some gaskets but lately it hasn't been running very well. My truck usually idles well but then when I go and drive somewhere it feels like it is studdering, if that makes sense. I tried some carb cleaner on it the other day and that didn't do anything. I am also about to change the spark plugs, wires, and points. I hope that it may be one of those things. Does anyone have any suggestions? Thanks.
Designated A-hole!
Re: 1970 C10 Problems
Welcome to the board from South Mississippi. Change your fuel filter while you're at it.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Saving 1 truck at a time!
Welcome from South Seattle (Kent). Where are you located? A tune-up is a great place to start. The next option would be replacing all the vacuum hoses and you might be a carb tune-up and rebuild. I would then do a compression test to see what condition the engine is in. There are several inxpensive books (Haynes Techbook 10305 - Chevrolet Engine Overhaul Manual) that are easy to read and will nearly make you an expert on these old V-8's if you digest everything in them.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
Next project: 1970 K10
What gaskets did you replace? Anything related to the card or intake?
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
find yourself a nice hei dissy
its all about the +6 inches
welcome to the board.
your studder ismost likely a misfore, and your tune up should probably fix it. Instead of putting new points in it, you should consider an HEI upgrade. You can do it cheap, and it'll make the driveablilty , off idle power, starting, MPG.... it'll help all of that... plus, you won't have to mess with the points...ever. |
Thanks for all the responses guys. How easy it to replace the distributor with an HEI? I was actaully wondering about this myself since I have no idea how to change the points and neither does my dad.
i did one of those accel points eliminator kits on my truck. $80 and about a half hour in the driveway. didnt even have to remove the distributor.
The first thing I did for mine was HEI. I got an ok one off Craigs List for $20. You will need to get new wires, but that is part of the tune up anyway. It takes about 20 minutes and a power wire. I ran a new wire off the fuse box, switched 12 volts, and you're good to go.
Set the motor to TDC and that's it. |
#10 | |
no brain no headache
![]() heres a couple of threads that will help ya ![]() http://67-72chevytrucks.com/vboard/s...ad.php?t=17403 http://67-72chevytrucks.com/vboard/s...d.php?t=148346
1996 GMC Sierra z71 ![]() 1970 SWB 2wd (project) ![]() |
Will I really notice much of a difference with an HEI? I have been talking to some people and they have said it is not too hard to change the points so I have been thinking about just doing that.
Why chainge points every 6 to 8 months, they are getting less and less common at the parts house, MPG and throttle responce increases, and starts up a lot quicker... all good reasons to use HEI.
