Old 10-27-2006, 12:41 PM   #1
wdsteeves
Question 87 to 66 front clip?
I recently bought an 87 1/2 ton for frontend parts swap.I am thinking it may be easier to cut the frames and weld the 87 to the 66 burb.Anyone out there done this?Any info/pictures would be greatly appreciated.I also want to lower the truck as low as I can without air.I have visited many suppliers sights,ECC,CPP etc.Being new to this I am boggled.As I live in British Columbia (freight costs) it is critical that I order the right stuff the first time.I know what I would like to do with the truck(if parts are available)I guess I need to talk to people who have there rides done,rather than a parts guy who may not know his stuff.Any help would be greatly appreciated.Thanx
wdsteeves is offline   Reply With Quote
Old 10-27-2006, 03:11 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: 87 to 66 front clip?
You should be able to unbolt the 87 crossmember and bolt it into the 66 frame. There will be one hole on each side that doesn't line up and will need to be drilled. If its an 88 front end then you will need to get the torch and the welder ready!
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 10-30-2006, 05:16 PM   #3
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
^He is right. Im putting the front clip off of a 76 GMC onto a 66 c10 right now and there are 2 holes that dont line up and if you use the newr power steering pump as well then there will need to be two new holes drilled. Its not all that hard. The rear axle will most likely not just bolt right up unless you plan on 4 linking it. I will be getting a rearend out of a 71 or 72 coilspring truck to bolt up.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
