Old 08-15-2002, 09:43 AM   #1
A.K.
fRAME INTERCHANGE?
I have a 72 chevy and need a swb frame. Can someone tell me if the 67 up frames all interchange or is it specific years. I realize that disc brakes were only on the 71-72 models, but it's mainly the frame I'm interested in.Thanks
A.K. is offline   Reply With Quote
Old 08-15-2002, 11:53 AM   #2
srhart71
THEY INTERCHANGE FOR 67-72 IF YOU HAVE SAME OPTIONS. (2WD/4WD, COILS OR LEAF, BED LENGTHS, ETC...
srhart71 is offline   Reply With Quote
Old 08-15-2002, 12:58 PM   #3
Shane
Shane's Avatar
I am pretty sure the section of the frame where the power steering box bolted up is different on the earlier years (67-68). Non power steering trucks are different than the power steering frames. I have never done this conversion, but I am sure someone on the board can help you out and tell you the differences.
Shane is offline   Reply With Quote
Old 08-15-2002, 09:23 PM   #4
chevytruck68
i dont think they are diff from the power and non power i had no prob bolting up my 75 power steering and disc brakes on to my 68 2wd
68 chevy 2wd long step lowered 67 chevy 3/4 4x4 83 gmc suburban 350 od auto 3 in body lift
chevytruck68 is offline   Reply With Quote
Old 08-16-2002, 11:57 PM   #5
Pont
I need another Barley Pop
Pont's Avatar
from what I have seen, the 69 & newer steering boxes have a buldge on the side of the box. The 69 & newer frames have a deprssion on the frame to accept this buldge. My 67 frame has no buldge and the 77 power steering box I used would not bolt to my frame because of this. Spacers had to be made to set the steering box away from the frame.
Here's a pic of a steering box that has been spaced from the frame but it is not the way I did my truck.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 08-31-2002, 07:49 AM   #6
NGN
NGN's Avatar
frame interchange
My 67 frame has no depression for the power streeing box , my friends 68 does . What I read on this board sometime ago was that 68 haft way though the year and up had the depression. Also recall that that section of the frame could be heated up with a torch to make the depression needed to clear the power steering gear box
NGN is offline   Reply With Quote
Old 09-02-2002, 04:27 PM   #7
chevroletrucks
Been There Done That!!!! I'm building a 67 with the help of a 71 and a 68 I tried to steal the p/s from the 71 and it don't fit after looking at the 71 frame I see why there is an indention on the 71 to accept the p/s.
chevroletrucks is offline   Reply With Quote
Old 09-08-2002, 02:15 AM   #8
dmnall
dmnall's Avatar
Exclamation
I added a 79 Power Steering Box on my 68 LWB, the only problem that I ran into was the front Bumper Brackets had to be cut out because the PS box was Longer then the Manual box was! Other than that, it was a direct bolt on !!
1968 C10 Truck LWB Fleetside
1968 C10 Truck SWB Stepside
1994 K2500 Ext Cab Fleetside
2008 Honda Civic Si *lease*
dmnall is offline   Reply With Quote
Old 09-08-2002, 02:41 AM   #9
Fast68Chevy
Fast68Chevy's Avatar
most late 68 have the commmon 68-up large p/s gearbox depression and most 67 and early 68 dont, but have seen one 67 so far that has the depression, is a 67 panel delivery
i have owned a handful of 68;s and all have been large p/s box adaptable trucks- are depressed for them,
bracket for bumper has to be trimmed to allow clearance for the larger new style p/s box
good luck
Fast68Chevy is offline   Reply With Quote
