10-28-2006, 08:37 AM | #1 |
1" or 1.25" rotors?
I need brakes and rotors on my 86. How do I tell what thickness of rotors I have? Can I convert to the 1.25" rotors if I have the 1" rotors now, or will I have to change spindles and calipers for that?
10-28-2006, 10:08 AM | #2 |
You get what you pay for
Re: 1" or 1.25" rotors?
In order to get 1.25" rotors you have to change spindes and calipers also. It's a total swap, spindles, rotors and calipers.
Oh, and to tell what thickness of rotors you now have it's just a simple matter of measuring them.
Mike 1985 Chevy C-10 Last edited by swervin ervin; 10-28-2006 at 10:10 AM. |
10-28-2006, 10:19 AM | #3 |
My 86 had the thicker rotors stock
10-28-2006, 11:02 AM | #4 |
Insert Witty Text Here
Mine has the light duty, 1" ones. You won't know unless you measure it.
Slonaker |
10-28-2006, 09:55 PM | #5 |
What if they're worn down pretty thin? What's the minimum thickness?
11-27-2006, 12:18 PM | #6 |
dang its hot
1.25 rotors are not likely to be worn below 1.0,although, it is stamped on the back of the rotor
