Old 10-28-2006, 03:56 PM   #1
el curioso
el curioso's Avatar
Hard brakes??
What does it mean when the brake booster has brake fluid inside of it?
Is this fluid suppose to be there?
I replaced the brake master cylinder and the brakes are still stiff.
In the case it Say's delco.
It comes from a 72 Chevy c-10 and is on a 69 Chevy c-10.
Does the brake master cylinder use a gasket where it meets the brake booster? I know it uses a grommet what im talking about is on the actuall mating surface. and if the grommet is a bit torn can this be cause for the hard brakes? It was like that on the 72 and it worked fine and I don't see why I would be having these problems now.
Any input would be a appreciated. Thank you in advance.
1969 Chevy C-10 350/700r4
el curioso is offline   Reply With Quote
Old 10-28-2006, 04:02 PM   #2
Aarons72s
Re: Hard brakes??
Question 1: No there should not be fluid in the booster.
sounds like a defective master cylinder. Is it rebuilt? Where did it come from?
My friend went thru a couple master cylinders on his 78 ford f250. The rebuilt cylinders he kept getting were pos. Problem was were auto zone parts, only place around at the time.
I ahve seen some with a gasket around the flange and some dont. When I replaced mine I just put a thin bead of silicone to protect water from getting in there.
Thats about all I can offer.
Aaron
Aarons72s is offline   Reply With Quote
Old 10-28-2006, 04:11 PM   #3
el curioso
el curioso's Avatar
Re: Hard brakes??
Thank you for the quick reply an the master cylender is fro
autozone.I ll go and exchange it later on today. And follow the silicon tip while replacing it.
Old 10-28-2006, 04:14 PM   #4
el curioso
el curioso's Avatar
Re: Hard brakes??
What place do you guys recommend for the re built kit for the original master cylinder?? The bastards at auto zone don't carry them any more they only carry the rebuilt master cylinder.
Old 10-28-2006, 04:17 PM   #5
msgross
msgross's Avatar
Re: Hard brakes??
parts america website had one I thought...
msgross is offline   Reply With Quote
Old 10-28-2006, 05:31 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Hard brakes??
your booster is probably junk too.
The brake fluid eats the rubber diaphram, and causes the hard pedal.
No need for a gasket or sillicone, just bolt it on.
Old 10-28-2006, 06:19 PM   #7
Aarons72s
Re: Hard brakes??
Go to oreillys. They actually carry brand new ones. I also got a rebuilt one from oreillys. Real nice rebuilds to.
Aaron
Old 10-28-2006, 06:45 PM   #8
el curioso
el curioso's Avatar
Re: Hard brakes??
Will have to get a new one . Is there a way to test to see of the booser works Like presurisind it or some thing similar?
Old 10-28-2006, 07:45 PM   #9
st1x10
st1x10's Avatar
Re: Hard brakes??
Vac guage. Put some vac to it and see if it holds it. Not to much though. It sounds to me like it is bad though, if there is a hard pedal. I would test it though, just so you don't spend extra money you don't need to.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 10-28-2006, 09:06 PM   #10
A.P.
Black 72 Chevy
A.P.'s Avatar
Re: Hard brakes??
http://67-72chevytrucks.com/vboard/c...uct=1095&cat=2
A.P. is offline   Reply With Quote
