Old 10-28-2006, 05:15 PM   #1
1968chevyprerunner
Disassembly of Front A-Arms
I am getting ready to disassemble the front A-arms on a 1968 Chevy C10. They are rusted and gunked up. I have heard horror stories about trying to get these things off. Any hints. Also, when I am rebuilding them, what are the most important things to replace?
Thanks,
1968ChevyPrerunner
1968chevyprerunner is offline   Reply With Quote
Old 10-28-2006, 05:45 PM   #2
jugernot
Life, Be In It.....
jugernot's Avatar
Re: Disassembly of Front A-Arms
Soak them in liquid wrench or ww40 or something. Use a powerfull air tool. If you are doing the bottom be carefull not to strip the threads on the A arms. I might be easier to leave them attached to the frame while removing the nuts. ( less for you to hold onto that way)
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 10-28-2006, 08:27 PM   #3
Ram-Man
Ram-Man's Avatar
I dont think I would have got mine apart without a torch. A little heat on the bolts will make life much easier.
Ram-Man is offline   Reply With Quote
