Old 10-28-2006, 08:13 PM   #1
bigbassmann
bigbassmann's Avatar
Back up light help needed
I have all lights on my truck working now except the back up lights. I have replaced the bulbs and the fuse is good. I checked the back up switch and found that the p.o. had disconnected the wires and had removed the connectors from the wires. I replaced the connectors and hooked the wires back to the switch. I still don't have back up lights.
Any suggestions on what I need to check next?
Could the switch be bad and how do I check it to find out?
bigbassmann is offline   Reply With Quote
Old 10-28-2006, 08:43 PM   #2
Bob Moore
Re: Back up light help needed
Stick or automatic? If automatic maybe the N/S-Reverse switch is out of adjustment. Don't know about sticks but could also be out of adjustment. Have you connected the wires bypassing the switch? If you have bypassed and still have no lights either a bad ground or a break in the wire.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 10-28-2006, 08:52 PM   #3
70c10
67-72 Addict!
70c10's Avatar
This isn't exactly an answer but it's an old thread that may help. I used a toggle mounted on my shifter like Matthufham did. The point of this is if you have a cheap ($2) toggle switch you can run 2 wires off it to your backup switch and test it at least. Here's the thread:http://67-72chevytrucks.com/vboard/s...=backup+lights
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-28-2006, 08:53 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Oh, and here's a pic of them after coating the inside of the housings with silver foil tape!
Jim
Old 10-28-2006, 10:41 PM   #5
bigbassmann
Bob, I haven't tried bypassing the switch. I will give that a try and see what happens.
Jim, the toggle could be a problem for me. There is no way I will remember to turn it off and the cops around here would just love that.
Old 10-28-2006, 10:52 PM   #6
skokie
skokie's Avatar
Not trying to hijack this but lets say your truck was a manual and you converted to auto. How do you get the reverse lights to work? Will I need a new wiring harness?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 10-28-2006, 10:56 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I have mine run on a toggle, and I too was forgetting to shut them off, so i got one od those toggles with a bright red LED in the end of it.
hasn't failed me yet.
Old 10-28-2006, 11:14 PM   #8
70c10
67-72 Addict!
70c10's Avatar
My toggle lights up when on so it's easy to remember to turn it off. The other cool thing about having that light back there is if you need to hook up a trailer or need some light behind the truck to do something.
Jim
Old 10-29-2006, 01:27 AM   #9
Longhorn Man
I get ppl to back off in traffic with that one... ald also to turn off there high beams.
Old 10-29-2006, 11:12 AM   #10
Smitty
Smitty's Avatar
Skokie, I found a harness from an automatic and changed out the plug. Matching the wires to the terminals by their colors. Works great for me. As for adjusting the switch. I put the shifter in reverse, loosen the screws on the switch and move it slowly one way or the other until the lights come on in the back. Lots of luck.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
