10-28-2006, 10:35 PM | #1 |
turbo enthusiast
'75 to '67 swap
I can pick up a '75 3/4 ton 4x4 truck for next to nothing. How hard would it be to transfer the front and rear differentials and the suspension over to my '67 suburban 1/2 ton 4x4?
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting " |
10-29-2006, 07:18 AM | #2 |
Re: '75 to '67 swap
Front, trans and t-case will bolt in, the rear will need spring pads moved.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
10-29-2006, 10:10 AM | #3 |
Re: '75 to '67 swap
springs are different lengths also but have seen them converted/perverted. Check out Senators posts. With the complete donor vehicle you could use the later model spring with perches on the earlier frame. Not exactly sure, haven't gotten to it yet, but i think the frame widths are about the same. So if you used the later springs and perches on the earlier frame might not have to change the spring mounts(widthwise) on the rear axle.
Drill out the old perches, mark, match and measure a few times then drill new holes, bolt the perches on with grade 8 hardware. The later model leafs are longer so they will give you more suspension travel and probably better ride depending on the type/condition of the springs, plus easier/cheaper to get all spring lifts which are always better than blocks for the 2-8 inch lifts |
