Old 10-29-2006, 12:59 AM   #1
skokie
skokie's Avatar
Where do you look?
I think I have a rear seal going out. This is the engine.
10066036...350...........2 or 4...Target Master/Goodwrench crate motor, 2-piece rear seal
How could I tell for sure? I was just under there and noticed a little oil on the tranny dust pan and starter bolt.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 10-29-2006, 01:42 AM   #2
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: Where do you look?
Pull the dust cover and shine a light up in there and look between the flange that the flexplate bolts to and the back of the block. If it's wet, it's probably the rear main. Could also be a converter seal......
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 10-29-2006, 02:04 AM   #3
skokie
skokie's Avatar
Will check tomorrow and post back. Thanks
68 build thread
Old 11-04-2006, 01:44 AM   #4
skokie
skokie's Avatar
Well I finally got under there and had a look. That flange looks dry. Here is a pic. However the 1/2 bolts and the first 2 3/8 were very loose. I snugged them up and cleaned up the area. Going to keep a eye on it. Also lesson learned tonight is that IF i have to swap out a oil pan gasket or a seal that engine is coming out
68 build thread
Old 11-04-2006, 10:09 AM   #5
jamon8
jamon8's Avatar
the rear main seal is going to leak a little no matter what the condition
if there is any puddle overnight bigger than the size of a dime you have problems
try tightening you oil pan bolts
they tend to loosen up over time
jamon8 is offline   Reply With Quote
