Old 10-29-2006, 02:00 PM   #1
Boise69
The Hammer Man
Boise69's Avatar
Arrow Painless or painful???
I'm considering buying a Painless wire harness for my 69. My current harness is not too bad but ever since my sarter problem i've been exploring the harness and have found some afro rigging here and there... should i painless or not and is it as bad as i've seen hinted? is there a better harness out there or should i just correct the bastardations as i find them??
Boise69 is offline   Reply With Quote
Old 10-29-2006, 02:07 PM   #2
texas69truck
Re: Painless or painful???
I just recently used a painless harness in my truck and it was fairly easy. It was my first time wiring anything and i managed to figure it all out. I had a friend helping who had just re-wired his 83 using a kit from LMC and he said the painless was much better.
texas69truck is offline   Reply With Quote
Old 10-29-2006, 02:20 PM   #3
Boise69
The Hammer Man
Boise69's Avatar
Thank you.
That makes me feel better. I dont know, it just makes me feel better to have all new wiring. A good winter project i guess.
Old 10-29-2006, 02:24 PM   #4
Boise69
The Hammer Man
Boise69's Avatar
Another question... if i'm planning on putting a new crate ZZ383 in it, should i replace my current wire harness? does it matter? wouldn't the 383 connect the same way as my current 350ci?
Old 10-29-2006, 04:25 PM   #5
drewmangoo
drewmangoo's Avatar
Question Re: Painless or painful???
what's afro rigging
Keep knockin' on the Devils door, eventually someone's gonna answer.
1965 c10 Longbed Fleetside
1972 Chevelle (wife's car)
2002 Suburban (wife's car)
drewmangoo is offline   Reply With Quote
Old 10-29-2006, 04:41 PM   #6
Boise69
The Hammer Man
Boise69's Avatar
Afromatic - the act of or form in which one puts together without rhyme or reason
Old 10-29-2006, 05:21 PM   #7
Pole Kitty
I used a painless in my 68 and it was painless, really.
Pole Kitty is offline   Reply With Quote
Old 10-29-2006, 05:45 PM   #8
Boise69
The Hammer Man
Boise69's Avatar
it included everything you needed to re-wire the whole truck? how much was the kit and where did you get it from? Sumit has it for 310.00
Old 11-30-2006, 02:34 PM   #9
z7199
z7199's Avatar
Did opne on my 72 ALOT easier than I thought it would be
99 nbs 5.3L x-cab Hypertech programmer
True dual 1 chamber flowmasters
magnaflow x-pipe 3" PA body lift
315/75/16 BFG All Terrian 15.3 @ 89mph
72' C20 402ci sc,lb in bed tool box, and new paint
http://www.cardomain.com/memberpage/456511/1
z7199 is offline   Reply With Quote
Old 11-30-2006, 02:36 PM   #10
sleepyboy
'69 Step
I did my 69 step; minimal hassles. I got tired of chasing wire gremlins from P.O.
sleepyboy is offline   Reply With Quote
Old 11-30-2006, 02:39 PM   #11
Rokcrln
Rokcrln's Avatar
I have done several (10-15) painless full vehical harness and I like to use the universal GM column 18 circut kits. It gives you more wire and the option of re-routing wires right were you wnat them as well as a few extra circuts for added items you might want to add down the road. But their factory replacement harness is easier to install for the first timer.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-30-2006, 03:29 PM   #12
Boise69
The Hammer Man
Boise69's Avatar
Kevin
LFD Inc.
If I understand correctly, Dont use the Painless harness, use the Universal GM column product? Do you have a link for this harness on where i can get it so i know its exactly what youre refering to?
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Old 11-30-2006, 05:25 PM   #13
zacut
67 chevy SWB Fleetside
Boise69
I am here in Rockford and my 67 has a Painless 18 circuit harness in it if you want to check it out. Both harnesses mentioned above are Painless. They have a standard replacement and a universal 18 circuit (as well as a 12 circuit I think).
I bought the truck with the harness laying in it and then I wired it (so far). I would say it was very easy. The wires are all labeled and printed right on the wire.
The advanatage of the 18 Circuit is that you have extra circuit compared to stock for thinks like power windows, electric fuel pumps, etc.
zacut is offline   Reply With Quote
Old 11-30-2006, 05:37 PM   #14
Boise69
The Hammer Man
Boise69's Avatar
Originally Posted by zacut View Post
Boise69
Rockford huh? That would be great. Are you still in the process of re-storing or are you done? I'd really like to see what you've done and hell yea meet with you to chat it up. My truck is in my warehouse up in Roscoe. PM me too.
ted
1997 MBZ E420
Old 11-30-2006, 05:42 PM   #15
shifty
Questionable
shifty's Avatar
As long as everything in the truck (including drivetrain) is from that same era, painless is great from what i hear. Painless gets painful when you start dealing with swaps like mine where they try to generate hydbrid wiring for you.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-30-2006, 06:23 PM   #16
Boise69
The Hammer Man
Boise69's Avatar
Well I have an Accel HEI and a Mini High Torque starter... would that make a difference?
1997 MBZ E420
Old 11-30-2006, 06:55 PM   #17
bryanw1968
bryanw1968's Avatar
I rewired my brothers '57 chevy pickup. Was very easy. Painless offers quite a few different options. You can buy anything from the basic kit or something that will support power windows, t.v.'s and gobs of stereo options.
Good luck.
B-dub
bryanw1968 is offline   Reply With Quote
Old 11-30-2006, 07:18 PM   #18
CMars45000
CMars45000's Avatar
So does the painless harness plug directly into the OE ignition switch, wiper switch, headlight switch, wiper motor, etc?
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 11-30-2006, 07:30 PM   #19
woodchip
Check out Modern Chevrolet Classic/Muscle WWW.oldmusclecars.com Go to section 8 Wiring harnesses. Dash Harnesses $295.00 Engine Harnesses$55.00 +$12.00 for /HEI Front lights $135.00 + $20.00 for internal Reg alternator. I have install the Engine&Front lights Harnesses & was easy no problem,haven't got to the dash yet' but should be no problem I am located just outside Winston Salem so its a local pickup for me,no shiping.
btw these harnesses are just like the Org.
98 Chevy Z71 1500 extended cab
99 Dodge carvan es
68 Chevy C10 LWB 50TH 396 eng 400 Trans
62 Wheel Horse tractor in good shape
woodchip is offline   Reply With Quote
Old 11-30-2006, 09:56 PM   #20
roj2323
hey bosie, i've installed a painless harness as well, between the 3-4 locals we have around here we should beable to knock out your truck in a few hours. i'll bring my heat gun and heat shrink so it's done right.
ondrew
roj2323 is offline   Reply With Quote
Old 11-30-2006, 11:48 PM   #21
shifty
Questionable
shifty's Avatar
Close enough to stock. Look at it this way: If it's using the same power/signal wires, you probably need not worry.
My old engine (L6 250) used 5 wires to make it run and have dummy lights. The new one has about 60 wires to make it run. To boot, the new drivetrain is from a car built 33 years later Big diff''ce there.
Old 11-30-2006, 11:49 PM   #22
shifty
Questionable
shifty's Avatar
It's supposed to - that's why they call it "Painless"
Old 12-01-2006, 11:07 AM   #23
zacut
My truck has HEI and the harness supported that. The ignition switch and some of the others were direct plug in connections. Head light and some others required the standard bulb plug to be spliced in. I soldered and heat shrunk all of my connections too. Roj is right, get 3-4 of us locals together and it would only take about a 1/2 day to lay a harness in a clean truck.
