10-29-2006, 04:12 PM | #1 |
what engine temp????
might seem like a silly question but what should my engine temp gauge be reading? in the uk we work on celcus but the gauge in my chevy is in ferenhiet, any numbers please
10-29-2006, 05:35 PM | #2 |
Re: what engine temp????
Mine is around 200 or so. It should be below the boiling point which is 212.
1970 Chevy C10 "Under Construction" 2002 Chevy S10 V6 |
10-30-2006, 11:56 PM | #3 |
thermostats are rated at two different tempatures. 185 and 195. i typicly put a 185 in my truck just becuse i think it runs better that way but the truck came with a 195.
ondrew |
10-31-2006, 07:30 AM | #4 |
ACTUALLY... YOU CAN GET THERMOSTATS DOWN TO 165 DEGREES UP TO 195 DEGREES IN 5 DEGREE INCREMENTS. IF YOUR COOLING SYSTEM IS WORKING PROPERLY, YOUR ENGINE TEMP. SHOULD NEVER GO MORE THAN A FEW DEGREES OVER WHAT YOUR THERMOSTAT IS RATED FOR. EXAMPLE...WITH A 180 DEG. T/S.... AT 180 DEG.s YOUR THERMOSTAT OPENS ALLOWING COLD WATER TO ENTER YOUR BLOCK FROM YOUR RADIATOR, THUS COOLING OFF YOUR BLOCK & CLOSING YOUR THERMOSTAT FOR THE CYCLE TO REPEAT ITSELF. CLEAR AS MUD HUH?? JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
10-31-2006, 02:03 PM | #5 |
my gauge never goes above 120f, has the belt driven fan plus two front mounted eletric fans, is this to low?
10-31-2006, 06:47 PM | #6 |
yes..........you have to have it hot enough to burn off the deposits that engines leave in the oil. Plus to a certain point heat wise the hotter the better efficiency
11-06-2006, 08:57 PM | #7 |
mine seems to be hitting 230-235 (summertime, texas heat, a/c on.) don't know what thermostat i have, but should i be concerned? measured from aftermarket sunpro mech gauge.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett '72 Blazer Restoration Blog: http://sportchicken.blogspot.com/ |
11-06-2006, 09:44 PM | #8 |
Our pickups were designed for 180° F. thermostats. Manufacturers later went to 195° thermostats for reduction of emissions. The down side of the 195° thermostats is that they create much higher pressures in the cooling system resulting in much larger leaks and components fail sooner. Most of the time if you use a 160° thermostat, you can remove the radiator cap and drive around all day without experiencing any problems. This is a plus if your cooling system has any leaks or is weak.
