Old 10-29-2006, 04:24 PM   #1
bigerealty
bigerealty's Avatar
Routing exhaust 67 swb
Could I please recieve some pictures of how to route 3" exhaust out the back of a 67 SWB pickup. I am looking to go air ride in back as well. Tank is in stock location behind seat. We are lowered approx 5" in back now.
Tight, Tight, Tight
bigerealty is offline   Reply With Quote
Old 10-29-2006, 05:00 PM   #2
jerry moss
Born Psycho
jerry moss's Avatar
Re: Routing exhaust 67 swb
do your air bag set up and any other mods before you take it to a muffler shop. i've been doing exhaust for well over 20 years and believe me, you'll be money ahead if all mods are done first so your muffler man knows what he has to miss. if your truck has leaf springs in the rear and a steel floor bed, it can be done as long as you do some crossmember massaging. if its a coil spring truck and/or a wood floor truck, i wouldn't attempt it unless you aren't concerned about how it looks--there will be some ugly/tight bends. definitly get some good heat shields for the bed floor, especially if you're going to run flowmasters.hope this helps.
p.s.-unless you're running a ton of horsepower, 3" is overkill and without some backpressure, gas motors lose lowend.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 10-29-2006, 06:39 PM   #3
bigerealty
bigerealty's Avatar
Smile Re: Routing exhaust 67 swb
Thanks, Coil spings, Oak bed, big block crate approx. 450 hp. series 40 Flowmasters. It will loose some size due to the bends not being Mandrel. sounds like the exhaust might be infront of the axle. Still would like some pictures if people have them.
Old 10-29-2006, 08:01 PM   #4
see ten
WTB this ad
see ten's Avatar
I have a 6" drop and the exhaust is tight! The driver side is where it's going to be the worst.
see ten is offline   Reply With Quote
Old 10-29-2006, 08:10 PM   #5
bigerealty
bigerealty's Avatar
Nice and tight. looks great or at least it works. thanks for the picture i appreciate it.
