Mexican cluster - $150 shipped
Here is a cluster from Mexico. The writing is in Spanish. My plan was to restore this and hang it up, but after nearly a year I still haven't touched it so I will pass it on to someone else.
I have not tested it so I can't tell you if it works. Someone painted parts of the bezel red, and there is a hole in the bezel under the speedo, you can see it in the pictures. It comes with the two plates shown, not sure what they are. $150 shipped
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Born Psycho
![]() Join Date: Feb 2001
Re: Mexican cluster - $150 shipped
never saw one like that before.
TTT for you ![]()
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
turbo enthusiast
that would add a custom touch to someones truck
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
wish I had the spare cash for this.....
Oilfield Trash
still got it?
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
Yes, I still have it.
That's different.
what are the words for lights, wiper and choke etc. Where's the harness plug in?
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
The upper right hole is labeled LIMPIADORES which I thought meant cleaning?? Maybe someone with a Spanish background can figure it out.
The hole below that is LUCES which I think is lights The other side is AHOGADOR which is choke The KPH speedo has a logo on it which reads "Jaegar" and under that is "I.P.A." Another different thing is that the bright indicator is at the bottom of the speedo. The middle dummy lights read GENERADOR (generator obviously) and ACEITE (oil) The last one is GASOLINA, FRENOS (brakes), AND TEMP No plug, everything is wired seperately. There is a main terminal to ground the cluster. I see three gray wires which are the cluster lights. A lighter gray which is the bright indicator. A white, pink, and brown which are the turn signals. Not sure why the one turn signal has two wires coming off it. The other side has three terminals, I am assuming one is for the gas sending unit, one for the temp sensor, and the other for the brake sensor.
Still Green but learning
thats neat TTT
-- Cory 71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab 07 Suburban LTZ 4x4 2010 Acura TL 98 Mastercraft "FrankenStar" 225 27253 UPS/USPS IIOY....nope never was |
I can do 90 shipped
67 is sold
Nice item for sure! Good luck with the sale
