Old 10-29-2006, 11:32 PM   #1
hgs_notes
GEARHEAD
hgs_notes's Avatar
Whatcha git dun this weekend?
I cleaned off the hood, moved the engine and stand out of the way, opened the garage door and drove it for probably the last time this calender year. It was a beautiful day today, with a poor forecast coming.
All the hard work cleaning the dust and paint overspray (from house doors, not the truck, unfortunately) from the windows, was well worth it. I took my 10 year old boy (future owner) for a nice loud ride.
A beautiful day indeed.
HG
hgs_notes is offline   Reply With Quote
Old 10-29-2006, 11:35 PM   #2
abadsvt
abadsvt's Avatar
Re: Whatcha git dun this weekend?
I finally figured out what i am going to do as a brace for the rear shockwaves. I was having a hard time trying to think of a cool way to mount the top of the shockwaves. Now i just have to make 2 small brakets and the rear end is done .
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 10-29-2006, 11:40 PM   #3
corkscrew
Well on Friday I lifted out the stock 350 and transmission. I am now cleaning up the wheel wells and other such things, Sanding is the main thing, getting them ready for paint. Then hopefully in a couple of weeks I will be able to drop in my brand new transmission along with my 383 stroker Im stoked, Its hopped up and I cant wait!!
corkscrew is offline   Reply With Quote
Old 10-29-2006, 11:42 PM   #4
1969k10stepside
I got the 6 inch lift on the 69 K10.
1969k10stepside is offline   Reply With Quote
Old 10-30-2006, 12:47 AM   #5
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
fri. ordered my drive shaft and th400 1310 yoke
sat. hung over like hell, bougth a new battery, swapped steering wheels.
sun. swapped steering wheels again, this one didnt need the 3" spacer which put the wheel to my chest.
with in 2hrs [7pm-9pm] i found out that the flood light i was using at 6pm stopped working, my newish 12k warn quit working, my buddies rear cv drive shaft slip yoke is hopelessly stuck together and my new light switch isnt working right again. yeah :-(
trkklr77 is offline   Reply With Quote
Old 10-30-2006, 01:16 AM   #6
TooT
Active Member
TooT's Avatar
Got the new fuel pump, dual fuel inlet, and fuel filters from summit...went to put them on and had the wrong fittings for the fuel inlet....just ordered two little coupler fittings from summit for $23 couldnt find them anywheres in town! gotta have them to complete everything though...
TooT is offline   Reply With Quote
Old 10-30-2006, 06:27 AM   #7
69TowRig
I didn't even get to look at my K5 this weekend, much less work on it.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 10-30-2006, 06:41 AM   #8
Saturday I changed out the last of the original power window regulator/motor setups in the wife's Bonneville. Piece of &^$% design andpain to get at. I also touched up, what I could, the Dodge's paint where someone had keyed it. Did somemore sanding on the 70.
Sunday, I played hotwheels and Legos with the son.
Old 10-30-2006, 06:51 AM   #9
cdowns
cdowns's Avatar
spent time on my "almost new" harley project mounted up new seat then spent some time on the luggage carrier(recieved from the netherlands this week) a little more grinding on the welds and the rack will b ready for paint
Old 10-30-2006, 07:44 AM   #10
Southedisto
River life......
Southedisto's Avatar
Finished my passenger floor, and installed the rocker box.
Southedisto is offline   Reply With Quote
Old 10-30-2006, 08:53 AM   #11
BowTieOgre
I pulled the donor engine/trans out along with the associated wiring harness and moved the freshly cleaned frame for the '70 back in the garage.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 10-30-2006, 08:59 AM   #12
oj70chevy
250 V-6 Club
oj70chevy's Avatar
Good morning everyone. First I installed new idler and pitman arms on my 93 gmc. Then I replaced the seals on the rear axels along with new breaks in the back. And to finish on Sunday I fixed the blower on the AC and got it aliened.
1970 Chevy C/10 6 Cyl. 43k original miles all factory .http://67-72chevytrucks.com/vboard/s...d.php?t=197523
Never ask a stupid question unless you want a stupid answer .
oj70chevy is offline   Reply With Quote
Old 10-30-2006, 10:21 AM   #13
LockDoc
The Older Generation
LockDoc's Avatar
Got some painting done. Core support, grille, & splash pan. Don't laugh at my paint booth......
Also bagged (pun intended) an Air Ride setup for $600. It's off of an El Camino but hopefully I can make it work on the '70. One of the front bags has a hole in it so I will have to replace it, other than that it's in good shape. The guy didn't like the ride with them on.
It's supposed to be 70º here today and a high of 42º tomorrow.... Welcome to Iowa..
LockDoc
Leon
Old 10-30-2006, 10:45 AM   #14
gouldie
broke down, rebuilt the carb, replcaed the fuel pump and got a battery
gouldie is offline   Reply With Quote
Old 10-30-2006, 11:19 AM   #15
b&a72
Active Member
b&a72's Avatar
Tore off bedsides and the rest of the body panels.
b&a72 is offline   Reply With Quote
Old 10-30-2006, 11:47 AM   #16
49studebaker
49studebaker's Avatar
Lifted the cab off it's dolly with my buddies service truck crane, undercoated it with Eastwoods rubberized undercoating, and then sat it down on my freshly painted chassis. I had recently installed 2 1/2 inch dropped spindles and 4 inch lowering leaves. I really like the way it's sittin'. Looks good with the RamJet engine. Soon as I get the funds, I'll be ready to order a FCG gas tank. Oh ya, also took the Studebaker for one last drive for the year. I did get waves and smiles from others I didn't know. Classic trucks makes people smile!
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 10-30-2006, 11:49 AM   #17
Lippyp
English Chevy Owner
Lippyp's Avatar
Today rather than the weekend, got the patch at the bottom of the passenger door pillar welded in and ground down. Treated it with rust convertor. Also wire wheeled the passenger floor and treated that too ready to paint. Tomorrow I'll primer the pillar and get the door ready to go back on so's I can fit the outer rocker.
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 10-30-2006, 01:18 PM   #18
CochinoFilipino
CochinoFilipino's Avatar
-stuck a digi camera behind the engine and was dissapointed to find 5.0 instead of 5.7. But at least I know why she lacked power.
-Got frustrated with an ebay acquired scanner.
-Replaced TPS and got the truck running again. She runs great.
-more frustration with scan tool. Verified all my ECM and ALDL wiring
-Pulled 5.0 EFI engine and AOD trans from parts Mustang.
-Helped uncle pull engine from his 55 Chevy.
'67 C10 Short Stepside 5.0TPI/700R4
CochinoFilipino is offline   Reply With Quote
