A guy with a truck
Rear bags in stock spring location- step inside
What do you do to relieve the bags when jacking or putting your truck on a lift? Don't want to over-extend them, as my truck somehow always ends up on the lift for one thing or another...
Ideas? -Chris
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Epoxy Primer Friendly
Re: Rear bags in stock spring location- step inside
shocks should help, or you could use a travel limiter.
Happy to be here
![]() Join Date: Mar 2000
Yeah, the shocks "should" limit the travel. Just make sure they do if you are running the sleeve style bags in back. They are more prone to pull out than the double convoluted style.
Some shocks don't work well as the limiter. The seals will pull out & start leaking causing the shock to fail.
A limiting 'tether' or strap made from simple braided steel cable that can be attached to the shock bolts should work.
A guy with a truck
This is kinda what I was thinking. Thanks for the input guys. -Chris
Offroad shops would have something similar. They're called limiting straps and they're made out of really thick nylon, like a seat-belt, but thicker. Wouldn't have to paint them or worry about them rusting like a braided steel strap either.
![]() Join Date: Mar 2004
a couple nylon ratchet straps should do the trick. best of all they're cheap. 14.99 at menards i think.
its just $$$$$
A guy with a truck
Also a good idea, and not permanent. I like.
