outer rocker & cab corners.........
has anyone done a write up on replacing the OUTER rocker panel and cab corners ? i seen the write up on replacing the inner but no outer/cab corners.
thanks lance |
Re: outer rocker & cab corners.........
don't know about a write up but make sure you fit them with the door hanging. iv'e had trucks where they were to high and forward and doors would never fit properly
common sense isn't so common anymore |
Junior Member
I replaced mine last weekend along with the rocker panels. It was kind of a pain but with a little modification the panels finally fit. **The repo panels are close but not exact so be prepared for a little work to make them right and also make sure that your doors so you can line them up correctly
1971 GMC 4x4 SWB 1970 GMC LWB 2002 Mustang GT 2004 Honda VTX 1800c |
chevy truck fan
qkenuf4u,
i did the exact same things as mentioned, but i went ahead & had a body place do it for me. i wanted them to be right & be able to take it back if they weren't. i can give you the name of the place, it is in tempe just off the 202 if interested. to have the above done plus some floor work was around 1,200. let me know if interested??? good luck! rodstored-72 |
Active Member
![]() Join Date: Oct 2006
How much were they bodywork wise rodstored-72? I am looking for a good place to do my bodywork and paint but not kill me on price.
E Fab man has DVD's available where he goes thru the process
The Hammer Man
"E fab man" i'd like to get a hold of that DVD, how do I?
What Qksilver said. I got the DVDs and done my own cab corners, rocker
panels,floor panel,and a few other things.turn out great. Just go to this site www.ebfabman.com
98 Chevy Z71 1500 extended cab 99 Dodge carvan es 68 Chevy C10 LWB 50TH 396 eng 400 Trans 62 Wheel Horse tractor in good shape Last edited by woodchip; 10-30-2006 at 08:31 PM. |
The Hammer Man
:tj: Sorry for the hijack.
thanks for the website. has anyone used them and are they any good ? what is the typical cost of geeting this work done by a body shop? |
It's all good and i have a donked truck! lol nope on the truck
Post pics of your cab corners because I have done a few sets and do not like how they fit. I usually cut up the cab corner and just use a portion of the metal. Hard to explain but minimal cutting if possilble but depends how bad your corners are.
Commander Taco Bello
i have one corner that is bad, but it's not a big hole. Is it realistic for me to cut down the piece that i put in so that if i screw it up, i can take it to a real body shop and have them cut out around any mess i make, and drop in a full cab corner?
hope that makes sense. |
#13 |
That is a good way to do it and the way most body shops and I do it. What is the use of cutting out good metal just to replace it. You would not cut off a man's good leg to replace it with a artificial one would you. Same with your rockers. I know on these trucks just like on my '69 some of the rockers are all gone but if the back is good and the front is bad buy a replacement cut out the bad part replace with the good tack it in then finish it up. Like was said make sure your doors are where you want them and are lined up and if there are any work to be done to the bottoms of them like rust repair do it so you don't run into a surprise later on after you patch your door and then it will not fit your cab corner or where you fixed the rocker.
'07 G6 Wife's car '00 Malibu stock, just a parts getter. '99 Blazer LT Loaded, K&N Filter, Pioneer Super Tuner,Viper '88 K1500 Cheyenne, 5.0, stock, bought new '86 Nissan 720 Trash Truck '69 C/10 step side, 307, all original, second owner, in process of restore. The person who says it cannot be done should not interrurt the person doing it. Share your knowledge. It is a way to achieve immortality. Allen- Paintman Wrenchtwister Broompusher |
