outta the car velocityboy
Has a Crossmember been removed?
Hi guys,
Am stripping my frame down to get blasted. Only the front Suspension X Member and the transmission Xmember to remove and its good to go. One question though.... Between the front suspension X meber and the Transmission X Member there are two rivets through the bottom of the frame on each side. They look like they have been cut a long time ago but I cant see what they would have retained... IS there supposed to be an additional X member here or is somethign else missing. Can post pics if it helps. Truck is a 72 SWB Step. It originally had a 400ci and I believe it was a MT but is now a 350ci with a TH400.... Cheers Lee
That is where the old 4-speed X-member was located. Removed to make way for the auto. This is A Mod that I have done. Its all good.
![]() Gary
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
Re: Has a Crossmember been removed?
Thanks Gary. Appreciate the feedback...
