10-30-2006, 02:33 PM | #1 |
starter wiring and altinator braket questions
Hi my name is Casey and im new to this web site. I have a 1967 Chevy C10, It has the 327 with the three on the tree. i got the truck about a week ago and the engine and trany was out of the truck and all wires that connect to the starter where disconnected. how do i tell which wires go to the starter, and which ones go where. My second question is how is altinator braket mounted. if at all possable i would like to get a picture.
10-30-2006, 03:16 PM | #2 |
Re: starter wiring and altinator braket questions
Originally the alternator was on the drivers side. A lot of people put the 73up brackets which locates them to the passenger side. As far as the starter wires I'd have to see to tell you. I don't have a picture I can acess for you right now either..
10-30-2006, 03:18 PM | #3 |
ill try to find a digigal cam and take a few pics. thanks for your help.
10-30-2006, 03:39 PM | #4 |
its all about the +6 inches
the purple wire goes on the S terminal, the yellow wire goes on the R terminal, and the big ass red cable... well, it goes on the giant stud.
1st pic shows how it goes on the engine... but it's on the hood. The hole on the lower left of the arm uses the same bolt as the left side on the cradle. 2nd pic shows the 2 holes you'll be useing on the heads. 3rd shows where the cradle goes. Last edited by Longhorn Man; 10-30-2006 at 03:47 PM. |
10-30-2006, 06:52 PM | #5 |
Designated A-hole!
Looks like andy has you covered, so I'll say Welcome to the board.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
10-30-2006, 09:02 PM | #6 |
You have a good resourse close at hand for electrical help. Mark @ MAD electric is just up the road in Spingville.
http://www.madelectrical.com/index.shtml
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
10-31-2006, 03:41 PM | #7 | |
10-31-2006, 04:10 PM | #8 |
You are absolutly right... I missed that fact.
And again, that came off a 71 C/20 Longhorn with a 307. Anyone have photos of the 67/68 brackets? |
11-02-2006, 10:12 PM | #9 |
i had to use the top right bolt on the water pump for one of the holes and the two holes at the end of the exhaust mantifold on the driver side. all i need to do is get some new bolts for the fan, get the fan in, and get the radiator in and see how she purs. after all that frustrating crap is over, i still need to take the engine back out clean it up for paint and paint the engine bay, if the engine does need to be rebuilt than it gives me a reason to swap the crank out with a stroker crank, and possable port the heads.
