10-30-2006, 05:41 PM | #1 |
Active Member
ECE trailing arms
Was wondering if anyone has these and what your experiences are with them?
10-31-2006, 12:04 AM | #2 |
Re: ECE trailing arms
I saw the new ones also. They sure look nice but I am using originals. I have a very nice pair of 3/4T trailing arms(stonger than 1/2T).
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
10-31-2006, 08:19 AM | #3 |
67 is sold
3/4 ton trailing arms are not the same as 1/2 ton trailing arms?
10-31-2006, 01:06 PM | #4 |
They're the same w/the exception of re-inforcement plates attached to the top/bottom of the arms to help limit flex & keep the seams from splitting under the stress of a heavier load.
10-31-2006, 03:21 PM | #5 |
67 is sold
Exactly the same, only different
10-31-2006, 03:35 PM | #6 |
at least these look nice unlike some others i've seen. ondrew |
10-31-2006, 04:18 PM | #7 |
Active Member
Mine on my truck are pretty hammered and since I am doing a restore I want to replace them, I know ECE makes quality products, and for the price I guess I can't complain too much.
11-01-2006, 05:54 PM | #8 |
Never Ending Projects
Looking at the picture, isn't it basically square tubing with a bend on the axle end and a piece of tubing for the bushing to press into at the front? This could not be hard to build for dirt cheap. Humm.....
11-01-2006, 05:58 PM | #9 |
Active Member
There is a thread on the main page of somebody making there own and I am following that as well.
11-01-2006, 07:33 PM | #10 |
Insert Title Here
LMC sells them for $299
http://www.lmctruck.com/features/cb/CBCR1.htm
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
11-01-2006, 07:49 PM | #11 | |
Outlandish Trends - FL
-Bret 67 short-fleet sold! |
11-01-2006, 08:00 PM | #12 |
Active Member
i agree with 67 I had nothing but problems with there customer service and they are trying to get 299.00 each. I willl go to a scrap yard and find some before I pay that much for them!
11-01-2006, 10:40 PM | #13 |
as long as you sleeve the holes the u bolts go through and cap the ends, yea it should be fairly easy to fab up a set. i'm not sure i would cut and weld the bend into the arms though, unless i plated both sides for extra strength. all in all though i think it would be worth the time to make up a few sets.
11-02-2006, 12:36 AM | #14 |
its just $$$$$
yep I think I have about $60 in the ones that I made.
