Old 10-30-2006, 06:21 PM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
What is this part called?
I have two question;
(1) I'm planning on using a 9" or smaller power booster. The ones I have seen do not have the eye hole part attached. What is it called and where can I get one.
(2) I would like to use the original booster to firewall brackets. Any suggestions on which after market booster that will work with the OEM brackets.
I apologize for using someone elses pic
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 10-30-2006, 07:39 PM   #2
sleepyboy
'69 Step
Re: What is this part called?
Power brake booster pushrod?
sleepyboy is offline   Reply With Quote
Old 10-30-2006, 07:49 PM   #3
st1x10
st1x10's Avatar
sounds good to me
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 10-30-2006, 09:23 PM   #4
jugernot
Life, Be In It.....
jugernot's Avatar
I guess I should be a little more specific. The piece on the end with a hole through one end and the nut on the other. The piece attached to the push rod, the shinnier aluminum looking piece. I did not researched and think it is called a CLEVIS, where can I get just the CLEVIS?
Old 10-30-2006, 09:55 PM   #5
roj2323
if your truck currently has brakes it should have one. both power and non power brakes have the same "clevis". if you need one let me know i have an extra.
roj2323 is offline   Reply With Quote
Old 10-30-2006, 10:11 PM   #6
Bob Moore
I don't know where to buy a new clevis but try the board for a used rod and remove the clevis. I don't know how you are mounting your new booster but as you can see the 67/72 style uses a fulcrum to change the leverage. The 67/72 style boosters have a non-adjustable rod attached and the adjustment comes from the bracket to pedal portion. Sorry that's not clearer.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 10-30-2006, 10:16 PM   #7
BubbaGreen
check out www.mpbrakes.com, they have re-vamped there website, totally un-user friendly, but request a catalog via snail mail, they should have what your looking for.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 10-30-2006, 10:44 PM   #8
jugernot
Life, Be In It.....
jugernot's Avatar
Bob,
you have answered some question I had, but I'm confused about something. My brake pedel bracket (pictured) came off my truck and had all the attached pieces on it when I removed it from the truck. The push rod on the brake pedel bracket comes to a point. Also pictured is the booster and booster bracket (pictured) I got from a wrecking yard.
Here is my question; how do they connect to eack other? Or do I have two different styles?
Old 10-30-2006, 10:58 PM   #9
junkyardjohn
junkyardjohn's Avatar
GO TO NAPA & ASK THEM FOR A HEIM-JOINT. THEY'RE ABOUT $5. BEEN THERE-DONE THAT. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 10-30-2006, 11:03 PM   #10
roj2323
taken care of.
Old 10-30-2006, 11:22 PM   #11
Bob Moore
Jugurnot - The brake pedal you removed from your truck was it manual or power? Looks like manual - direct to the mastercylinder. Only the power brakes have the fulcrum setup.
vac, 454, T400
more to follow
Old 10-30-2006, 11:34 PM   #12
jugernot
Life, Be In It.....
jugernot's Avatar
Bob, Now that you mention it, the cab did have manual brakes on it. So what do I need to convert the manual brake pedel setup to a power brake set up?
Old 10-30-2006, 11:41 PM   #13
Bob Moore
Get a power brake push rod. Should have a hole on one end (fulcrum) and the clevis on the other(brake pedal).
What is on the end of the rod coming off the fulcrum now?
vac, 454, T400
more to follow
Old 10-30-2006, 11:47 PM   #14
jugernot
Life, Be In It.....
jugernot's Avatar
Lightbulb Re: What is this part called?
Now I get it. Someone is finally home and they have turned on the lights. There is another question for you. I have noticed that alot of the after market boosters do not have a Fulcrum or a Clevis on them, so how to you attach the after market booster to the OEM booster braket?
Thanks for the lesson.
Old 10-30-2006, 11:53 PM   #15
jugernot
Life, Be In It.....
jugernot's Avatar
Originally Posted by roj2323 View Post
taken care of.
Rog2323, I sent you another PM
Old 10-30-2006, 11:58 PM   #16
Bob Moore
Jugernot - That I don't know. They must have some bolts or holes for some. I now the new truck is extra cool - do you not want to run the old brackets and a refinished booster? I would think Rockrin could come up with a way to mount a new booster.
vac, 454, T400
more to follow
Old 10-31-2006, 12:11 AM   #17
jugernot
Life, Be In It.....
jugernot's Avatar
I have thought about a new booster. I am just concerned about complications with getting it all to work. I'm sure I'm thinking to much about it and it is probably really simple. I really want to clean up the engine compartment, so less would me better. A small booster that sits close to the firewall would be great.
Old 10-31-2006, 09:15 AM   #18
grayw0lf
Is anyone else running power brakes, but without the intermediate linkage? In other words, the two eye holes (the rod from the pedal & the rod from the booster) are bolted directly to eachother?
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
