Header Opinions
What are some of your guys header opinions. What company do you like the best, meaning fits well, flows well, most horsepower gain if any. And what should I look for in a header? 16 guage steel 18 guage, 3in collector or 2 1/2 or does any of that make to much of a difference.
Re: Header Opinions
I will subscribe to this, I would like to know as well.
1970 Chevy C10 "Under Construction" ![]() 2002 Chevy S10 V6 ![]() |
Re: Header Opinions
every set I've ever had, you always need to trim a little material off the inside frame rail on the passenger side. On a mild to moderate small block you will make more power across the range with 2.5 collectors, your gonna' end up with 2.5, or less, forward pipe so you might as well avoid bottle necking the flow by drastically stepping it down from 3" collectors. Small blocks with less than 350 HP need a certain amount of back-pressure to retain low end torque, so don't go crazy with large pipes.
wouldn't it be great if we where all like Forrest Gump.? |
Re: Header Opinions
What brand have you used joe?
Re: Header Opinions
hooker, dynomax, hedman, cyclone, I always prefer to trim the frame instead of dinging in the tube.
Re: Header Opinions
I noticed you own an S-10, had one 'bout a year ago with a 350, see pictures
Re: Header Opinions
Sweet truck here is a pic of mine.
![]() It is my daily driver.
Re: Header Opinions
Ok what about the guage of the steel. Does it make any difference on the heat or longevity of the header? So where any of those that you mentioned joe any better than any of the other ones?
1968 C-10 longbed, 307 V8, 4spd- currently under construction ![]() ![]() |
Re: Header Opinions
The thicker the better. The thicker it is the less chance it will flex.
Re: Header Opinions
What does it mean when it is advertised as " only for off-road use". Does that mean it is too loud or what?
The LuvShack Garage
Re: Header Opinions
I luv mine, lots of pic's in the "GQ" siggy link, NO FRAME mods, and
NO PIPE dinging, they also have the newer style BALL collectors, I have Hedman "ELITE" Ceramic Coated, they were $275 to my door, the flanges were so thick I had to TOSS my ARP bolts & use theirs.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
Re: Header Opinions
What size collectors on those and where did you get them?
#13 |
The LuvShack Garage
Re: Header Opinions
Summit
Jeg's They are not pictured on the Jeg's website, and the Summit pic is WRONG, I have never installed anything easier in my life and am extremely happy ![]() *If you look at my pic's in my siggy u will see that they are 3/4 length ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 10-30-2006 at 09:03 PM. |
#14 |
Re: Header Opinions
there ya' have it.
#15 |
The LuvShack Garage
Re: Header Opinions
I'm going to order a pair for my Jimmy soon as I have time to call Hedman
again in Cali and confirm the right part number, I called Summit 7 times in the past before I ordered the other set, then called Hedman, then called to Jeg's and ordered them, 7 calls to Summit, 7 different part numbers ![]()
#16 | |
WTB this ad
Re: Header Opinions
#17 |
![]() Join Date: Aug 2001
Re: Header Opinions
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#18 |
Re: Header Opinions
make sure you take notice while tightening your headers, they don't touch the frame until they've been tightened and you have to look real hard to see it.
#19 |
![]() Join Date: Feb 2001
Re: Header Opinions
I have had several different sets of Hookers and never had any kind of fitment problems. Granted my frame is newer but the fit seems to be about the same as was on my daughters 72 Blazer. Her's was close.
#20 |
Re: Header Opinions
Anyone running the elites on a 2 wheel drive c-10? Can you confirm the part number is 69890?
Thanks any pics in c-10 would be nice?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
#21 |
Re: Header Opinions
I have Ceramic coated Hooker Headers & love em, no leaks, great scavenging the cylinders & great sound.
#22 |
Re: Header Opinions
#23 |
67-72 Addict!
Re: Header Opinions
I have HookerSuper Comps on mine and the fit is good. The other thing to consider is how easy the spark plugs are to access. Hookers are all easy!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#24 |
Re: Header Opinions
I think they say for offroad use only because of smog or sound or something of that nature.. you want a nice thick gauge flange and also the thickest gauge for the tube also for reasons of rust and durability, they will last longer. I have thorley tri-y's and had to grind the frame back a little but they only touched the frame a tiny bit other than that, I have no complaints.
#25 |
Re: Header Opinions
So buying the Hooker Comp. headers and the Hooker exhaust system from Summit would probably be the best way to go. I mean the exhaust system is supposed to fit exactly to the headers and the headers sound like they have no problems really so it should work out good.
